Old 08-06-2014, 11:27 PM   #1
engineer_gregh
engineer_gregh's Avatar
Stock Steel Wheels
I'm unsure how to measure stock steel wheels to know if they are a truck pattern or car pattern. I have a 71 half ton and I would like to find some standard stock wheels to go on my truck. Can someone help me with how to measure or what to look for? I have a nice set of original full hub caps ready.
engineer_gregh is offline   Reply With Quote
Old 08-07-2014, 04:58 AM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Re: Stock Steel Wheels
I found a plastic bolt circle template at a swap meet, I'm seeing them in the auto parts stores lately too. It's just about a 6" round disc with a bunch of holes for about every bolt pattern made, they are marked for what size they are. It's really handy. Our trucks use the 5 on 5" pattern The cars were 5 on 4.75"
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 08-07-2014, 08:07 AM   #3
The way to measure 5-lug pattern is skip one and measure center to far side
Old 08-07-2014, 08:57 AM   #4
engineer_gregh
Thanks for the responses. I don't have a standard steel wheel but I do have a rally wheel. Am I measuring this correctly?
Old 08-07-2014, 09:18 AM   #5
geezer#99
geezer#99's Avatar
That looks right.
On some wheels it's easier to measure center of stud to center of stud on adjacent holes or lugs. 5 inch pattern is 2 15/16 checking that way.
Old 08-07-2014, 09:51 AM   #6
leddzepp
Moderator
leddzepp's Avatar
Yes
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-07-2014, 12:39 PM   #7
NO! You measured outside to center and I specifically stated center to outside! (hah hah)
Old 08-07-2014, 01:00 PM   #8
hanly2
I thought it was center to center? And its probably super hard to tell 5x5 from 5x4.75
hanly2 is offline   Reply With Quote
Old 08-07-2014, 10:24 PM   #9
michael bustamante
michael bustamante's Avatar
It looks right. Most 5 lug rallys youll find will be 5 on 5. If you are looking for steel wheels dont forget to get the 4 nub ones so theyll clear your disc brakes. 3 nubs will only work on drums.
1967custom
michael bustamante is offline   Reply With Quote
Old 08-08-2014, 09:45 AM   #10
engineer_gregh
Thanks Michael, I didn't even think about the difference in drums versus disk.
Old 08-09-2014, 10:00 AM   #11
Nope,you're not the only one. Just look at the picture. It's center to outside (or outside to center).
It's kind of hard to spot 4 3/4" from 5" without measuring,but it's easy with a tape. It's 1/4" different
