Old 08-07-2014, 08:07 AM   #1
csfields
csfields's Avatar
Tach Filter Question
I know this has been burnt up on other threads. I am still not finding what I am looking for. I am installed a factory tach, which was obviously junk, didn't know it at the time, so I purchased a new repo tach from Classic Parts and stated that I had to use a tach filter. I have read threads where some say it's needed etc. I figured since they recommended it wither for functional purposes or for a sale, I would use it. I just need the sime question of how to hook it up exactly. The tach like a factory one has the 12+ and coil terminals on the back along with a added ground post. I am just curious as to the proper way to get the filter inline with all this. Not quite sure I understand the directions. Call me stupid, just need some direction. I have managed to build this truck from the ground up, but stumped here.
I pulled pictures from other posts to show filter and directions.
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline   Reply With Quote
Old 08-07-2014, 08:09 AM   #2
csfields
csfields's Avatar
Re: Tach Filter Question
I know where the ground goes. I am thinking that the yellow goes to coil post on tach and that the red leads back to the coil itself? Do you all think this is accurate?
Thanks,
Casey
Old 08-07-2014, 09:25 AM   #3
No8Easy2
No8Easy2's Avatar
whats up Casey? yeah that's a head scratcher! the only thing I'm not 100% on if it go inline with the tach signal or just piggy back on the tach itself
this is the way i would do it
black to ground
red to (-) coil
yellow to tach
did it come with any other fittings that might help figure it out?
Chris
"They Don't write songs about Hondas "
1972 C10 "Ole Red--blood, sweet & beers"
USMC 1989-1997 1st Anglico
No8Easy2 is offline   Reply With Quote
Old 08-07-2014, 09:31 AM   #4
Zeke's Garage
Zeke's Garage's Avatar
Yes, the filter needs to be inline between the coil, red wire to (-) on coil, and yellow to the tach input on the tachometer, and black goes to ground.
The filter is used to cut down on 'rpm noise' on the radio coming from the coil. With a modern radio, or radio block-off plate, I doubt you even need one.
'67 Chevy Stepside
250 Inline 6
Megasquirt Fuel Injection
T5 5 speed conversion
Ferric Oxide impregnation throughout
Zeke's Garage is offline   Reply With Quote
Old 08-07-2014, 09:35 AM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
http://www.marshallinstruments.com/pdf/37.pdf
The link has better instructions.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 08-07-2014, 10:17 AM   #6
71K20chevy
71K20chevy's Avatar
I hooked my factory tach to my HEI without the filter and it works just fine.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 08-07-2014, 10:27 AM   #7
csfields
csfields's Avatar
Thanks guys for alll the help. These instructions really make it easier to understand. According to these instructions you can wire it backwards for increase filtering? I will try the standard way first and go from there. Thanks again for all the input. Sometimes you just get unsure of yourself and need a second or third opinion.
Thanks,
Casey
Old 08-07-2014, 10:35 AM   #8
TBONE1964
Cluster King
TBONE1964's Avatar
That's what we are here for Casey. Glad it helped you.
Keep up the good work on the truck. It is looking great.
Take care,
Tom
