PMP 69 BBC build
Thought I would share my bbc 69 build. Its pretty far along but thought it may help me push forward.
Re: PMP 69 BBC build
Driver side pic
Nice pic with my finger over the camera
So heres the run down on the motor. 468ci 10.75:1
850 cfm demon Victor jr intake Full roller motor Cam specs th400 reverse manual valve body Hurst quarter stick |
Motor just mocked up everything has to be re polished.
Suspension
eibach 2" fronts Eibach 5" rear Cpp 2 1/2 drop spindles Disc conversion 5 lug conversion Super pan hard bar shock relocaters |
Drive line
Coan th400 reverse manual Trans brake Line lock 4300 stall 4800 ballon plate 12 bolt 4.11 Auburn locker |
Wheels american force billet aluminum
Wheels
American force Burnout Rear 20x10 Front 20 x 9 Tires front nitto 235 35 20 Tires rear nitto drag radial 305 40 20 |
Wheels
Sorry I have to rotate all my photos. Some back ground on the truck. Born in 1968 Janesville wi and lived in east dubuque its entire work life. At 15 I purchased it for my car with lawn mowing money drove it every day to high school and a few years after. Its been sitting since I put the bb in because I didnt have the money to go forward and I new it was at a point in needed alot. Amazingly the paint is still pretty good even after I beat the heck out of it through its life.
Recovering Truck Driver
I like it! Very similar to where I want to be with my 67, except I won't drop mine...the county road to the highway sucks too bad and I'd be bottoming out all the time lol
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
#13 |
It has had alot of different motors first 283, then 350, 383 stroker. And now the 468
#14 |
I already know the front tire has to be larger. The pot holes are terrible here
#15 |
sounds like my 4x4, I think it's on motor #5. I bought the 2wd with the 454 in it running, but it drives like a sow and has a lot of performance parts in the top end, but still stock bottom end, so I think I'll take it all apart and start over.
#16 |
Theres no reason with the right shocks and springs you cant go that low I have plenty of room. Im more worried about bending a rim so the front tire is going to be a 245 40 20. Unless off roading lol my stock audi is still lower and my truck has more travel. Just an fyi
#17 |
Yeah, we see a lot of bent rims running low profile tires here. I may end up bagging it so I can change the ride height. That's if I even keep it, I've had it about a month and drove it twice....I think I have 5 miles on it now lol
#18 |
Guages are all pro comp mocked up
#19 |
My old man has a 57 that was bagged by ridetech we pulled it off and put a whole suspension change wirh adjustable coil overs. The car would suddenly drop on the interstate freaky as hell no brakes no steering. But to be honest thats the way I was going until we had all the problems.
#20 |
Rear drag radial
#21 |
Any one no how to rotate these pics or do I have to rotate them in my gallery
#22 |
Bed cover
#23 |
Ill post more once I get the rotation corrected
#24 |
Motor pic test
#25 |
Interior test
