Old 08-07-2014, 07:29 PM   #1
Kapote
Kapote's Avatar
2000 suburban runs fine then dies, until mass airflow is removed
So I've got a 2000 chevy suburban that runs fine normally, but recently it started acting up on trips. It will start to die and idle really low. Then you shut it off Nd wait and it will run for a min then die. However if you remove the mass aiflow it runs just underpowered , but I bought I new sensor and it does the same ? I've looked for an answr and haven't found anything I know this site is the best and someone knows!? Also sometimes if I play with the 4x4 it will start and go ... Anyone?
1984 k20 "Project as seen in my garage".
1968 C20 -292 dump bed
1987 Burb, 350TBI 700R4, RedNRusty
Kapote is offline   Reply With Quote
Old 08-07-2014, 09:10 PM   #2
truckdude239
truckdude239's Avatar
Re: 2000 suburban runs fine then dies, until mass airflow is removed
Have you cleaned the thottle body? Check the fuel pressure
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
