Old 08-07-2014, 08:36 PM   #1
88lsiroc
88lsiroc's Avatar
2001 up ac in 67-72 cab
Has anyone tried this? Just thought it would make a very tidy install compared to the big factory ac. My truck has ac already but I have a 2001 donor truck and could just swap it all out. I'm starting the ls swap and trying to use as much new parts/ technology as possible. engine accessories harnesses and all.
88lsiroc is offline   Reply With Quote
Old 08-07-2014, 09:02 PM   #2
71K20chevy
71K20chevy's Avatar
Re: 2001 up ac in 67-72 cab
Subscribed, I wanna know about this too.
I think it'd be pretty difficult dealing with the electronics, you'd probably need the BCM from the donor truck...
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 08-08-2014, 12:13 PM   #3
68blazer
68blazer's Avatar
i've got a 2008 donor and i was planning on doing the same!! i'm in too
68blazer is offline   Reply With Quote
Old 08-08-2014, 12:39 PM   #4
no1udknow
no1udknow's Avatar
the question is, has anyone swapped in an ac system from another vehicle/year, if so what fits best??
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 08-08-2014, 12:44 PM   #5
Bigdav160
Bigdav160's Avatar
This has come up before and I seem to remember someone saying they've done it.
I have a hard time believing because the space under the dash is much smaller on these trucks than newer trucks.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-08-2014, 01:09 PM   #6
no1udknow
no1udknow's Avatar
I'm wondering why none has made a full electric unit. There is plenty of room under the hood to put an electric motor driven compressor and condenser. Maybe even add a second battery to help power it
Built not bought!
Old 08-09-2014, 12:34 AM   #7
j-dogg
Here you go! This is board member ls1nova71. It's on an ls motor swap, but should give you some ideas if nothing else. Check out his full build - he does some really great work!
http://ls1tech.com/forums/conversion...0-4l80e-7.html
j-dogg is offline   Reply With Quote
Old 08-09-2014, 01:23 AM   #8
Ozzy2013
Ozzy2013's Avatar
Im in looking to put A/C in the 68 GMC and have been studying how to do this cheaply.
Ozzy2013 is offline   Reply With Quote
Old 08-09-2014, 08:01 AM   #9
1972CST
1972CST's Avatar
Check out the Young Frankenstein crew cab 72 build, pretty sure he did it.
1972CST is offline   Reply With Quote
Old 08-09-2014, 10:51 AM   #10
Bigdav160
Bigdav160's Avatar
This is the opposite of what the OP as asking about. In fact I don't see the purpose. A square body evaporator, accumulator and hose ends can be purchased cheap enough.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
