Old 08-08-2003, 12:34 AM   #1
70blazer
70blazer's Avatar
Question Adding power steering ?
I just bought a 69 3/4 4x4 that does not have ps. I want to add it and wanted to make sure this is a bolt up job. Do I just bolt on a power steering pump, change out the manual steering box for a power steering box and I am done? Any help and advice would be much appreciated. Especially where to pick up a good ps box and pump, can I use them out of the 73 and newer trucks?
1967 Suburban, my kids call it the SuburBEAN cuz its long and green.
70blazer is offline   Reply With Quote
Old 08-08-2003, 02:30 AM   #2
BUXMAN66
go bucks!
yup, ......might wanna pick up the hoses though!!lol! pretty easy mod. just make sure you have the pulley to drive the pump...and they're in line correctly.
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 08-08-2003, 02:47 AM   #3
Phillip Johnson
Phillip Johnson's Avatar
Ive done the complete job in a bit more than an hour. Cake walk
Phillip Johnson is offline   Reply With Quote
Old 08-08-2003, 02:59 AM   #4
SEVEND2
SEVEND2's Avatar
to add, May need to change out the pitman arm, the Hole diamention is smaller on a manual than on the PS one
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 08-08-2003, 03:18 AM   #5
GMCPaul
You will need a gearbox, hoses, pump, pump brackets, pitman arm & a integral power steering coupler. Watch out using 78 and newer pumps they went to using metric fittings at the hoses so don't mix a early pump with later gearbox or visa-versa.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 08-08-2003, 06:52 AM   #6
ZOOMY
ps
That's the best mod you'll ever do to a 4x4. They drive like a tank without it, and like a truck after.
ZOOMY is offline   Reply With Quote
Old 08-08-2003, 11:04 AM   #7
Jwill41
Jwill41's Avatar
cant go without the power steering
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
