Old 08-08-2014, 09:15 AM   #1
68joker420
Smile Needing help with my gas tank
Putting 2001 SS LS1 in 68 c10 short bed. Moving gas tank between frame , wanting a side fill tank, but didn't know which tank would be best for the buck that will work with motor ?
68joker420 is offline   Reply With Quote
Old 08-08-2014, 05:38 PM   #2
SierraMtns
SierraMtns's Avatar
Re: Needing help with my gas tank
Is it on a fleet or stepside?
SierraMtns is offline   Reply With Quote
Old 08-08-2014, 05:43 PM   #3
SierraMtns
SierraMtns's Avatar
Here is what the guys on Trucks did. Hope this helps.
http://www.powerblocktv.com/episode/...p#.U-VDnUgab-h
Here is how they did the side fill.
http://www.powerblocktv.com/episode/...s#.U-VEOEgab-g
Old 08-08-2014, 06:37 PM   #4
Lees68GMC
Lees68GMC's Avatar
Fleetside requires you to build an assembly to where you want your fill location, my buddies Mark and Tim did this copied it for my truck and love it. You figure your routing, get an exhaust guy to bend you up an 1-1/2" steel fill tube (exhaust pipe) and get rubber gas hose (NAPA or others) * MUST BE GASOLINE RATED HOSE ONLY. You can get a Fill neck assembly from Rock Auto for about $36.00 and fab the sheet metal enclosure and it works great.
You have to modify any tank you use to accept a OEM style GM / Delphi In Tank Fuel Pump and Fuel level sender group, about $125.00
Really easy for a step-side route your side fill location tucked up inside of the wheel well.
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
Old 08-13-2014, 02:18 PM   #5
68joker420
Is a fleet side. Not wanting to drape hose over side or have to put tailgate down every time. Seen side marker light used and is hidden, really like ! But didn't see inside bed if had to modify so when you fill up has right angle that the pump doesn't keep shutting off ? Would really like to see more pictures of it to see process.
Old 08-13-2014, 03:10 PM   #6
68joker420
Thanks for the videos sierramtns ! perfect
