Old 08-08-2014, 11:22 AM   #1
BigSix
Getting Water Through Side Vents...
Just tightening up my cab and noticed I get water through both side floor vents when the truck is parked and it rains. I dont think I really need those vents once I add AC. What would you do? Whats the best way to seal them? Weld or is just make a plate and silicon it on?
BigSix is offline   Reply With Quote
Old 08-08-2014, 11:40 AM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Getting Water Through Side Vents...
The water is coming from somewhere above those vents. Plugging up, or putting a plate over those vents won't solve the possible bigger issue.
Try and trace back how the water is getting in there.
66 C20 Service Truck:
Old 08-08-2014, 11:52 AM   #3
1963c-10
1963c-10's Avatar
May be holes in the outer box...common rust place and water will blow in
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-08-2014, 12:38 PM   #4
61K10
61K10's Avatar
make sure the drain holes in the outer cowl at the bottom are not plugged up. you can see the drain in this pic of my tk.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-08-2014, 01:27 PM   #5
63burban
Chevy addict
Your windshield may be the culprit
63burban is offline   Reply With Quote
Old 08-08-2014, 04:22 PM   #6
forestb
forestb's Avatar
Just move to California and you will not have to worry about rain getting into your cab.
forestb is offline   Reply With Quote
Old 08-08-2014, 06:14 PM   #7
AcampoDave
AcampoDave's Avatar
Sad and true, when I read the title of the post I was like...how does water get in there? But then I reminded myself that it does rain in other states.
AcampoDave is offline   Reply With Quote
Old 08-08-2014, 08:37 PM   #8
MailManX2
MailManX2's Avatar
Right above the hole for the side vent there is a splash guard, gutter thingy. If that's rusted it'll allow water into the side vents.
I ended up replacing the cowl on my 60 Apache and replaced the splash guard thingys too because they had quite a bit of rust where they were spot welded to the cab..
Ken B
60 Chevy Apache
2019 Chevy Silverado Z71
Why buy something when you can build it for twice the price..
Just because something can be done doesn't mean it should be done...
MailManX2 is offline   Reply With Quote
Old 08-08-2014, 10:16 PM   #9
LostMy65
LostMy65's Avatar
It's a good chance you're correct.
Mine was rusted out too.
What did you use to for a new splash guard thingy?
Originally Posted by LostMy65 View Post
I had a leak in the cab.
I found it at a seam under the vent cowl cover.
I dug into it yesterday.
There's about forty spot welds.
I wasn't looking forward to drilling all them out.
It went a lot easier than I expected.
Here are a few pics:
Got the patch piece from the donor cab cut to size.
Fits good.
I'll probably try and get it cleaned up and tacked in tomorrow.
Old 08-08-2014, 10:22 PM   #10
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Going thru the same thing now with my Burban
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-08-2014, 10:34 PM   #11
Softpatch
Softpatch's Avatar
thanks for the pictures ..."Very interesting"
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 08-09-2014, 09:45 PM   #12
MailManX2
MailManX2's Avatar
I just bent up a new piece of sheet metal and welded it into place.
Ken B
60 Chevy Apache
Old 08-09-2014, 09:55 PM   #13
ls60apache
im afraid im going to be doing the same thing......those vent holes will make nice speaker mounts after building a sealed cover.
ls60apache is offline   Reply With Quote
Old 08-10-2014, 11:11 AM   #14
cab_01
cab_01's Avatar
I just made some plates and covered them. I used sealant around the edge. I thought about putting speakers in there but worried about water getting in.
cab_01 is offline   Reply With Quote
Old 08-10-2014, 11:24 AM   #15
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
If you check out my burban build, you will see I am, doing the same thing now.
But since I will be going vintage air (which the vent gets a cover plate) I will be fabbing the whole inner structure out of a solid piece, eliminating the kick panel vent.
Drivers side as well.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
