Old 08-08-2014, 01:45 PM   #1
captain69
drive shaft alignment problems
So I took the truck out for its maiden beating and I can feel the trans or the drive shaft almost step out every once in awhile. Im not sure if its the locker in the rear end but its real bad with a little gas and taking a corner. I tried the trans brake and it almost seemed like it was in nuetral when I let off hope I didnt smoke the converter. Can some one show me a pick of there auto tail shaft height. I think the rear of the trans needs to come up.
captain69 is offline   Reply With Quote
Old 08-08-2014, 01:49 PM   #2
captain69
Re: drive shaft alignment problems
Since lowering it something has changed bad look at this angle does it seem right?
Old 08-08-2014, 01:50 PM   #3
kwmech
1 piece? 2 piece? tight u-joint? shaft alignment out (in phase?) carrier bearing jumping, slip yoke frozen?
ah, posting pics while I was typing, yeah, trans has to come way up, put the x-member inside the frame rail? Shaft appears too short also.
How far did you drop it?
Old 08-08-2014, 01:51 PM   #4
captain69
1 piece new drive shaft 4"
Old 08-08-2014, 01:52 PM   #5
captain69
Im looking more at the angle its just so low hard to show the angle
Old 08-08-2014, 01:55 PM   #6
captain69
Was thinking about raising the rear mount 1/2
Old 08-08-2014, 01:56 PM   #7
kwmech
Trans has to come up, maybe more than 1/2. How does it look at the axle?
Old 08-08-2014, 01:57 PM   #8
Keith Seymore
Keith Seymore's Avatar
It's angled the wrong way (assuming your pinion nose is down in front).
The front and rear u joints are adding their disturbances together rather than canceling each other out.
Rear of the trans has to come up quite a bit.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-08-2014, 01:58 PM   #9
Keith Seymore
D@mn. Tree'd by kwmech.
K
1979-1986
1986 - 2019
Old 08-08-2014, 02:00 PM   #10
captain69
Looks good in the rear. I guess always having it jacked up in the air I never noticed and when I was putting the super panhard in it seemd low.
Old 08-08-2014, 02:01 PM   #11
Keith Seymore
I'd be more comfortable if you had more slip yoke engagement, too (yoke farther into the trans).
K
1979-1986
1986 - 2019
Old 08-08-2014, 02:01 PM   #12
captain69
Ok ill jack it up put some spacers in and try it . Thanks just wanted to make sure I wasnt nuts.
Old 08-08-2014, 02:03 PM   #13
captain69
I had three shafts made freaking nightmare.its a coan reverse manual and the tail shaft has been a problem for fitment either the yoke wont fit or bottoms out
Old 08-08-2014, 02:04 PM   #14
captain69
Theres only a small amount it will go in 1/4 inch max
Old 08-08-2014, 02:05 PM   #15
captain69
Want to say its a long input shaft on a short tail its been awhile cant remember.
Old 08-08-2014, 04:24 PM   #16
88Ironduke
Just from the outset, I assume a turbo 350. Having made a trans cross member I can pass on a couple of things. I would figure out the process of getting the tail shaft up higher. Nothing else will work right until that is resolved.
I would rework that cross member to either bolt from the top of the frame or at least bolt to the sides of the frame with four Grade 8 bolts supporting the trans tail shaft. A nice large mounting pad to spread the loads out will ensure that transmission tail shaft is transferring rotational loads to the cross member/frame and not into the body of the transmission. It doesn't have to be pretty, just solid and reliable. GM put in a robust cross member into our trucks from the factory. The tubing you have chosen is sufficient to do the job it just needs more structure for when the pedal hits the floor.
Bring a new cross member inwards high up and drop it to the center and pick up the transmission. Doing so will also provide extra clearance for the already low hanging exhaust.
Good Luck.
88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 08-08-2014, 04:32 PM   #17
captain69
Ok well I have tried to move the th400 till its aligned but its hitting the firewall. Equal length headers are maxed this is what im doing. Putting the mount up top and recessing it. Already cut all the bolts to the shifter for room . But still not straight theres no way I can see
Old 08-08-2014, 04:43 PM   #18
captain69
Jacked up smashing into the firewall best it gets
Old 08-08-2014, 04:51 PM   #19
captain69
More
Old 08-08-2014, 05:02 PM   #20
davepl
davepl's Avatar
Time for some schoolin'
First, yes, lockers are annoying on the street. But they're either locked or not, more or less, so don't cause
But as for U-Joints, it is completely irrelevant how it looks (within reason). It does not matter what the angle is. What matters is that the angle is the EXACT same angle as the other end.
Which is why, boys and girls, they invented the constant velocity joint for applications such as front wheel drive (and IRS) where you can't guarantee the output shaft is parallel to the input. But with a standard U-Joint, any difference in angles will show up as a vibration.
Think of it this way: as one u-joint cap goes around it's furthest outward point, it's speed is different than the innermost. So the whole deal speeds up. But when aligned properly, the exact opposite (kitty corner?) cap on the other end of the shaft is on its inside sweep, so it exactly compensates. If the angles are different, they do not cancel each other out and you wind up trying to constant accelerate and decelerate your rear axle (or trans, I suppose) with every driveshaft rotation and that's never good.
If you care about vibration, I wouldn't try to eyeball it. You really need to get a magnetic angle finder, which is probably available at the dollar store, though if you value accuracy you might want to spend double that.
On my leaf spring truck the axle has a 'nub' that fits into a receiver in the spring pack, so you really cannot change the pinion angle on the rear axle (haven't looked at a coil spring truck in a long time so can't recall). That leaves you with only the angle of the engine & trans to work with.
I will assume you've got the basics covered, like the right trans hump (TH400s like mine came with the tall hump) and crossmember and mount.
With all the right stock pieces it should, as you would imagine, be right on the mark or close enough to it. But once things start changing, the onus is on your to keep the angles right.
BTW, same deal for left-right (as viewed from above) but I've never run into that. Then again I'm the last guy left at stock ride height so I never have these kinds of issues :-)
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-08-2014, 05:12 PM   #21
captain69
I have magnetic levels theres just no way its going to happen unless there is something else like lowering the motor. The pulleys up front are almost touching the electric fan.
Old 08-08-2014, 05:15 PM   #22
captain69
What do you think less than a finger maybe 1/4
Old 08-08-2014, 05:40 PM   #23
captain69
Ok quick fix operation must take the wife out to dinner in the truck you have spent to much on.
Old 08-08-2014, 06:24 PM   #24
davepl
davepl's Avatar
If this was a small block truck and now carries a big block, did you get the correct frame pedestals? I don't know the precise difference, but if the small block ones are taller, which I suspect they might be, then you're never going to get it high enough in the back without it hitting.
Also, how did you 'lower' this truck? With new spindles or has the body's position relative to the frame changed?
Old 08-08-2014, 08:30 PM   #25
captain69
Bib block motor mounts but now I think I might have hurt the motor. I cant win with this truck I swear. From jacking up the trans and motor my throttle linkage bent to wide open throttle and I didnt have a revlimiter chip in. Went to pull it of the ramps reved to the moon before I could shut it back down I have push button start and switches. Now gota pull the valve cover off got a tick in the back driver side hopefully a rocker is loose or just a bent pushrod and not a valve.
