Old 08-08-2014, 02:01 PM   #1
49tomchevy
49 about caught up
They never get done. 77 IFS Center line wheels with 1.5" front space to get inside fenders. 3" lowered coils in front, 2" blocks in back. 350 from 93 trk 350 turbo, Shark instruments, don't know what seats are out of. Was pretty mangled when I got her. Firewall cut all to pieces, no dash, but every thing has come together pretty good.
49tomchevy is offline   Reply With Quote
Old 08-08-2014, 04:01 PM   #2
eagleuh1
eagleuh1's Avatar
Re: 49 about caught up
Nice looking truck. Wheels and tires fit just like I like it. Jim
eagleuh1 is offline   Reply With Quote
Old 08-08-2014, 05:12 PM   #3
crossfire84
crossfire84's Avatar
nice!
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 08-14-2014, 07:39 PM   #4
49tomchevy
Interior work.
Old 08-14-2014, 08:10 PM   #5
nvrdone
Looks fantastic. a lot like where I'm going
How did you get the far left gauge mounted ? Did you have to cut out the mounts for the speedo?
Can you tell me what steering column you used and the length from the dash mount to the base of the steering wheel?
nvrdone is offline   Reply With Quote
Old 08-14-2014, 09:43 PM   #6
49tomchevy
Had to get the billet rings. The original rings from the dash did not look good. Did have to remove any mounts. Used a 3.5" drill hole cutter. I moved the light switch up to the wiper switch hole. You need to flatten the middle of the hole on each side. Tach says it is 3 5/8 but fits perfectly in the 3.5 opening. I'm not sure about the steering column it was in the truck when I bought it a few years ago. I think it is from a 77 pickup as is the IFS which was a problem. it was about 3" too wide. Special order Centerline wheels 18x7 with 1.5" front space to get them inside fender so I could lower about 3".
Old 08-14-2014, 10:09 PM   #7
49tomchevy
Re: 49 about caught up picture from start
Showing how old Rallies looked.
