Old 08-08-2003, 03:13 AM   #1
Linus0014
Guest
Posts: n/a
Gearbox T fitting
I got this gearbox to put in my truck. But I noticed it has a "T" fitting for the hoses. 2 of them are pressure hoses and 1 is a return line. I thought there was 1each for sbc?
Old 08-08-2003, 04:50 AM   #2
GMCPaul
The truck that was donor for gearbox most likely used a hydro-boost brake booster and they sourced the pressure to supply booster from power steering pump using a T fitting. Use a standard pressure type power steering hose to replace the current one with the T fitting.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 08-08-2003, 06:06 AM   #3
Linus0014
Guest
Posts: n/a
thank-you
