Old 08-08-2014, 07:23 PM   #1
blackbolt
blackbolt's Avatar
Swing away tire carrier
Guys I have a question I bought a tire carrier but the inner brackets are missing I think I saw them on here that someone was reproducing them but I've tried the search and I'm coming up blank I think I'm searching for the wrong words, any help would be appreciated thanks JJ.
blackbolt is offline   Reply With Quote
Old 08-10-2014, 11:16 PM   #2
warbucket
warbucket's Avatar
Re: Swing away tire carrier
Is this it.
http://67-72chevytrucks.com/vboard/s...d.php?t=597021
72 CST 4x4 Blazer, 1 ton
70 SS Chevelle, L78, 396
Everytime someone calls your Blazer a Bronco, God kills a kitten.
warbucket is offline   Reply With Quote
Old 08-10-2014, 11:50 PM   #3
blackbolt
blackbolt's Avatar
Thanks warbucket but after closely looking at his brackets mine are different, the mounts on mine have 6 hole mounts on the top bracket and the lower one has 4 holes to mount on and it bolts directly under the stop light.
Old 08-11-2014, 01:13 AM   #4
midunes
midunes's Avatar
could you post some pics
midunes is offline   Reply With Quote
Old 08-11-2014, 02:23 AM   #5
blackbolt
blackbolt's Avatar
Midunes tomorrow I'll have some pics for y'all
Old 08-11-2014, 02:25 AM   #6
blackbolt
blackbolt's Avatar
Here's one but it doesn't show what I'm talking about
Old 08-11-2014, 03:29 PM   #7
blackbolt
blackbolt's Avatar
A pic
Old 08-11-2014, 03:30 PM   #8
blackbolt
blackbolt's Avatar
Another one
Old 08-11-2014, 05:02 PM   #9
midunes
midunes's Avatar
those look like home made brackets. also the last pic show a outline of the correct bracket and 1 correct hole
Old 08-11-2014, 05:39 PM   #10
blackbolt
blackbolt's Avatar
At one point it had the carrier when I bought it somewhere along the lines it got removed
Old 08-11-2014, 07:11 PM   #11
midunes
midunes's Avatar
PM warbucket he might have a complete set (inner and outer) of brackets for you
Old 08-11-2014, 08:29 PM   #12
warbucket
warbucket's Avatar
It looks like the top inner bracket may still be in the panel. Maybe someone tried to remove the outer bracket and snapped the bolts. If you remove the side marker light and reach up in the panel you will find a metal rod. The rod is only used to push the inner bracket up into the corner. If that's the case you could drill and tap your inner bracket. Let us know what you find.
Old 08-11-2014, 09:35 PM   #13
blackbolt
blackbolt's Avatar
Nothing is there, when I bought it I found the lower and upper inner brackets just hanging and the rear fender where the blow out had curled up the fender I pulled them off without knowing what they were and I don't remember what happened to them.
Old 08-12-2014, 02:48 PM   #14
midunes
midunes's Avatar
pm sent
