Old 08-09-2014, 12:42 PM   #1
1966
TH350 and NP205 vents - they should always be unplugged right?
Crawling around under the truck to trace a leak, noticed both the transfer case and trans vents were plugged by PO (hose coming off both vents w/ plug in each hose).
These should always be open and able to breathe right?
1966 is offline   Reply With Quote
Old 08-09-2014, 01:09 PM   #2
vidman
vidman's Avatar
Re: TH350 and NP205 vents - they should always be unplugged right?
YES, They should be free to breath
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 08-15-2014, 09:51 AM   #3
72'Bourbon
Depending on what your doing with the truck, you may want to run a hose to vent them high and out of the water.. or mud.. sand.. etc..
72'Bourbon is offline   Reply With Quote
