08-09-2014, 12:47 PM | #1 |
Routing for Door Jamb Switch Wires?
I've started installing/re-installing my wiring harness. Thanks to a lack of pictures and short-term memory, I don't remember how to route the door jamb switch wires from the inside of the cab to the door frame. Can anyone share some pics or wisdom on this?
Also, if you've used a painless harness in your truck, did it come with the dome/cargo lamp harness? If it does, then I can add that to the list of things I've lost as well. Thanks, David
David Next project - 1953 Chevy 150 2 Dr Sedan. https://www.chevytalk.org/fusionbb/s...hp?tid/355913/ |
08-09-2014, 06:15 PM | #2 |
Re: Routing for Door Jamb Switch Wires?
The pictures below show how they go through the kick panels. Driver side is top, passenger side is bottom. Both sides originally had grommets.
08-10-2014, 08:50 AM | #3 |
Thank you, FirstOwner! I'll run to the hardware store and see if I can find something to use as the grommet.
David
