Old 08-09-2014, 01:36 PM   #1
Klundog
Heater Fan
Can someone help me with the proper sequence to remove the heater fan in my sons 68 C10 (no A/C)
Klundog is offline   Reply With Quote
Old 08-10-2014, 12:09 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Heater Fan
First off we need to know what is going on with the heater fan (blower motor). Why do you need to take it out?
LockDoc
Leon
Old 08-11-2014, 04:22 PM   #3
Klundog
Re: Heater Fan
Thank you for your reply.
The fan, well she's dead.
I tried to jump it with positive and negative and got nothing.
I have since determined I will need to remove the passenger side hood hinge.
I am hoping to secure the hood so I need only take off the one side. I believe but I am not sure that when the hood is opened, the hinge spring is at it's most relaxed state. I realize tension remains but it would appear to be fully extended .
Old 08-12-2014, 12:08 AM   #4
BlackedOut67shorty
BlackedOut67shorty's Avatar
Re: Heater Fan
You can drill with small drillbits on the hood hinges into the fenders to make sure your hood goes back on the way it came off without alignment issues
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 08-12-2014, 08:07 AM   #5
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Re: Heater Fan
The hinge spring is relaxed when the hood is open, just make real sure you have the hood supported at the front and on the side you take off so you don't bend the other hinge.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 08-12-2014, 09:40 AM   #6
LockDoc
LockDoc's Avatar
Re: Heater Fan
You do not need to completely remove it, just remove the bolts that screw into the inner fender. It won't go anywhere. and prop the hood front center and pass rear as mentioned above....
LockDoc
Leon
Old 08-12-2014, 10:25 AM   #7
Klundog
Re: Heater Fan
Thank you, thank you. I was a bit concerned about that.
