08-09-2014, 02:04 PM | #1 |
questio for folks with porterbuilt trailing arms
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
08-09-2014, 05:41 PM | #2 |
Keepin it old school
Re: questio for folks with porterbuilt trailing arms
buff fingers
08-09-2014, 07:45 PM | #3 |
I used a boxed end wrench, and worked out well.
08-09-2014, 08:46 PM | #4 |
Yours must be thinner than mine, that end didn't fit either. I guess I'm going to buy a cheap one somewhere an make it work. My wrenches are to nice to grind up lol.
08-09-2014, 08:53 PM | #5 |
It was a craftsman box end, and maybe those are a little thinner. A trip to Harbor Freight for a cheap box end to grind on, would be a good solution.
08-10-2014, 08:25 PM | #6 |
Paul - What size are they? I have some special wrenches that have thinned heads to fit into the bodies of some of the valves we service. They're metric, but I probably have one that's close. Sorry I didn't think about them when I was over there last week. - Matt
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
08-10-2014, 09:58 PM | #7 |
1 1/16" or 27mm....
08-10-2014, 10:00 PM | #8 |
They also sent nylock nuts that I'll use on final assembly that aren't as long. That will probably help some.....
08-10-2014, 11:43 PM | #9 |
Yep.... I ran into a similar deal when I used different hardware just for set-up.
08-11-2014, 11:18 AM | #10 |
We have found it also might be necessary to trim a little off the u-bolt to get the wrench out (if using the box end).
It can be a little frustrating when installing the nylocs... and not being able to get the wrench out from between the gusset and the u-bolt end. That's why we supply both styles of nuts. We use the nylocs for final assembly. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
