Old 08-09-2014, 05:00 PM   #1
bloody hammer
bloody hammer's Avatar
62 C10 Step w/ 235 - Test Results
I finally got around to picking up some tools I've been needing in my garage. I ran some tests today and here are the results...
Fuel Pressure = 4.5
Vacuum = 18 (steady at idle)
Compression (front to back) = 105, 130, 110, 130, 100, 130
As I understand it, the first two tests are good results but the compression... not so much. I guess the rings are going?
Is it at all odd that 2, 4, and 6 were all 130 but the others were around 100?
bloody hammer is offline   Reply With Quote
Old 08-09-2014, 06:43 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 62 C10 Step w/ 235 - Test Results
It's been a long time since I've done a compression check, but if memory is correct the next thing is to squirt some oil in the cylinders and recheck. If the compression goes up it means rings, if it doesn't it means valves, or I may have that backwards. I'd do a quick Google search and go from there. The other numbers sound great, and 18 inches and steady at idle probably confirms your valves are sealing well.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 08-09-2014, 08:27 PM   #3
bloody hammer
Thanks, Mark. I'm going to read up on it some more. I did discover one thing I forgot to do.... I did not open the throttle valve when "starting" the engine. I'm going to do the whole thing again except this time I'll jimmy the throttle open with a screwdriver or maybe just press down the accelerator each time. I'm curious to see how different the results are.
Old 08-09-2014, 11:31 PM   #4
bloody hammer
Ran the compression test again but this time with the throttle valve open. Much better results...
Cylinder - First crank - Final
#1 - 60 - 125
#2 - 60 - 125
#3 - 90 - 130
#4 - 90 - 130
#5 - 70 - 125
#6 - 90 - 130
Old 08-10-2014, 12:24 AM   #5
bloody hammer
Something I noticed after each time I tested.... for the first 5 minutes or so of running the engine the valves were tapping. Does anyone know why this would happen after running a compression test?
Old 08-10-2014, 01:54 AM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Great news, glad to hear it turned out healthy. Perhaps it's noisy lifters you're hearing rather than valves - if you have hydraulic lifters. The engine may be turning over so slow during the compression testing there isn't enough oil pressure to keep the lifters filled? Once the engine is fires up the higher engine speed pressurizes the lifters eliminating the ticking.
Old 08-10-2014, 11:33 AM   #7
bloody hammer
Yep, sorry... I meant to say lifters and what you said about not enough oil pressure makes sense. Thanks!
