Poly bushings failing?
What causes poly bushings to fail? Heat? Age? Miles? I have been tracking down a wandering issue on my 89 Jimmy and swapped out the front spring bushings and all the sway bar bushings. They were all blown out like this.
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
Re: Poly bushings failing?
Poly is really too stiff for a leaf spring bushing. The springs need to twist more than polys like. They are perfect for rotating in a single plane, but any more than that and they bind things up.
Yeah, despite the advertising hype poly is not a good material for all bushings. I used to go through two sets of lower control arm bushings a summer on an old turbo car I had until I build arms with spherical ends. Poly needs to fit perfectly and only move in one plane as diamond mentioned. There is a reason many companies stopped using it for shock/air ride bushing too. It just doesn't hold up. Ridetech won't even sell you replacement bushings for the old shockwaves now and recomend changing to sphericals.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel |
![]() Join Date: Apr 2005
How old are they?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
