couple of newbe questions
I have a 69 c10 ramp truck. It is currently sporting a 327 and 4 speed manual trans with 1 ton 8 lug running gear. I am wanting to swap in a 454, but am curious if I can still keep my 4 speed granny gear tranny. I don't know what kind or which model it is, I just know the gear ratios are really close, and it is really wound out at 60mph...I need to keep a manual trans. because of towing cars, etc. any help would be greatly appreciated.
oh yeah, oil pump failed today, and I locked it down, so a swap will commence shortly... ![]() |
Re: couple of newbe questions
Welcome to the site loads of great info on here for you you can use your trans no problem at all may need a different bell housing not sure. Also your gonna need some different motor "stands" or "perches" as they are different from small and big block. The winding out as you say of the motor is still gonna be in play as it is in the rear gearing of the truck and the trans isnt gonna help you there.Good luck start reading use the search and have some fun. Jim
#3 | |
I am doing the same on my 67 C50 327 but on C50's the motor mounts are in the front of the block like 55-57 chevy cars.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour Last edited by colgad; 08-10-2014 at 10:33 AM. Reason: added info |
ok, thanks guys. This sounds encouraging. I'll look into the motor mounts. Also, another thing I was considering was going either to a tbi setup, or doing a multi-port setup and going efi. The tbi's require a computer to control the injectors, right? I've done some searching, but have yielded only some vague results, or large build threads that are 20+ pages long...thanks again for the help guys! I have some decisions to make...
Welcome to the Forum. We live through each and every members explanation and PICTURES some time our mental images just don't line up. If you have a problem just ask someone knows the correct answer.
Here's some pics of it now
