Old 08-09-2014, 11:56 PM   #1
Ozzy2013
Ozzy2013's Avatar
Transmission cross member.
Hey guys help me out i have a 68 GMC i am converting to big block 5 speed manual.Its 6 cyl 3 speed manual .So i climb under the truck and the Trans crossmember is riveted to the frame!So how to cut the top rivets off with the body in the way?Thanks Oz
Ozzy2013 is offline   Reply With Quote
Old 08-10-2014, 12:18 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Transmission cross member.
Are you sure you need to remove it? Can't you use it for the BB/5 speed setup?
LockDoc
Leon
Old 08-10-2014, 12:28 AM   #3
Ozzy2013
Ozzy2013's Avatar
Looks awful hard to get the old trans out its a 3 speed manual my 5 speed is a nv4500 to heavy to be trying to shove this 250lbs tranny around it looks like a bolt in crossmember is in my future just don't know how i'm going to get the top rivets out.These nv4500 are very tall also .I couldn't find any 2wdrive conversion builds .
Old 08-10-2014, 09:57 AM   #4
hugger6933
Die grinder if you have the clearance or chisel the heads of course you knew that. A auto crossmember is what you were planning for right?
hugger6933 is offline   Reply With Quote
Old 08-10-2014, 10:52 AM   #5
colgad
colgad's Avatar
I used a cutoff wheel to cut an X in the head then a Air chisel to pop the head and the Air Chisel to push the rivet out of the frame. Not my idea of a good time.
I would like to know how you like the 4500 (once you get it in). i would like to swap out my granny 4 speed in my C50 for a 4500 someday.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 08-10-2014, 05:25 PM   #6
WIDESIDE72
WIDESIDE72's Avatar
LockDoc
With a 6cyl /3sold combo, there isn't really a trans cross member, just the mid mount one at back of engine. They are a bear to remove with cab on. I did one years ago with a "hot wrench". Last one had the cab off. Bought a parts truck once with a v8 conversion. PO just torched enough to get the engine I. Looked like ass. I sold the frame as is. New owner was gonna clean it up.
WIDESIDE72 is offline   Reply With Quote
Old 08-10-2014, 06:08 PM   #7
michael bustamante
michael bustamante's Avatar
Remove the lower brackets first. This will give you acces to x and chisel off the rivit heads on the upper ( main ) ctossmember. I just did this myself. Use an air chisel if you get a chance
1967custom
michael bustamante is offline   Reply With Quote
Old 08-10-2014, 08:25 PM   #8
Ozzy2013
Ozzy2013's Avatar
Thanks for all of the answers i will take it out from the bottom i was scratching my head on this one!
