Old 08-10-2014, 12:28 AM   #1
CaliforniaDaddy
CaliforniaDaddy's Avatar
96 S10 NV3500 5speed off 4.3V6 What Clutch To Use?
Im going to be using the NV3500 5 speed off 4.3 V6 1996 S10. Im planing to bolt it up to a SBC350 and wanted to know what clutch kit do I use? Can I use everything off the 4.3 V6 S10 engine?
“I would rather live my life as if there is a GOD and die to find out there isn't, than live my life as if there isn't and die to find out there is.”
CaliforniaDaddy is offline   Reply With Quote
Old 08-10-2014, 07:38 AM   #2
1project2many
Re: 96 S10 NV3500 5speed off 4.3V6 What Clutch To Use?
The 4.3 S10 clutch is 11" diameter and should work with a stock V8 flywheel. The 4.3 flywheel is different.
1project2many is offline   Reply With Quote
Old 08-10-2014, 07:57 PM   #3
CaliforniaDaddy
so If i want to order a new clutch kit im going to order a kit for a 96 S10, and then order a V8 flywheel? Like one they would use in the NV4500
So something like this and an S10 clutch kit and im good?
http://www.ebay.com/itm/Pioneer-FW10...e8848f&vxp=mtr
Old 08-11-2014, 07:09 AM   #4
1project2many
You need a flywheel to match the engine. If the engine is older than '86 it takes a different flywheel than the 86 and up versions.
Old 01-04-2015, 02:11 PM   #5
waid302
NV3500 with 2001 5.3 LS:
http://www.s10forum.com/forum/f213/b...blazer-477762/
waid302 is offline   Reply With Quote
