Old 08-10-2014, 01:23 AM   #1
Jocker64
The impossible is very much possible
My truck cab was a non-A/C and leaving in phoenix without A/C so I decided to make it a A/C cab
It took me about 6 hours to get it done
Looks great and you can not even tell that dash was changed other than the color
Jocker64 is offline   Reply With Quote
Old 08-10-2014, 01:24 AM   #2
Jocker64
Re: The impossible is very much possible
More pics
Old 08-10-2014, 01:25 AM   #3
Jocker64
Old dash already out
Old 08-10-2014, 01:26 AM   #4
Jocker64
No dash
Old 08-10-2014, 01:27 AM   #5
Jocker64
Firewall pads installed
Old 08-10-2014, 01:28 AM   #6
Jocker64
Prep new old dash
Old 08-10-2014, 01:29 AM   #7
Jocker64
Dash installed
Old 08-10-2014, 01:30 AM   #8
Jocker64
Dash installed 2
Old 08-10-2014, 01:31 AM   #9
Jocker64
Dash installed 3
Old 08-10-2014, 01:31 AM   #10
Jocker64
Dash natal led 4
Old 08-10-2014, 01:51 AM   #11
70shortfleet
70shortfleet's Avatar
Very nice job! Are you going to do the fire wall section also? Are you going to do a factory ac system?
70shortfleet is offline   Reply With Quote
Old 08-10-2014, 02:03 AM   #12
Jocker64
Factory all the way with the exception of the compressor and POA valve
What firewall are you talking about? The factory ac will fit in the original location just need to cut a little were the outside box goes
Old 08-10-2014, 10:10 AM   #13
Kennuck
Kennuck's Avatar
Nice work on changing the dash out. Just curious what is the advantage of changing the whole dash out. I just cut the holes for the a/c vents in my original dash took about an hour. Am I missing something? I'm going with vintage air.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 08-10-2014, 10:29 AM   #14
LockDoc
The Older Generation
LockDoc's Avatar
I think he is talking about the differences in the firewall between A/C and non-A/C as shown in the picture below.... Looks like quite a bit of difference to me. Plus the flapper in the cowl vent area, plus the kick panel vent, and under dash and engine compartment wiring looms. Also the core support has to be drilled for the condenser lines. Just so everyone reading this thread knows that retrofitting a factory system is not a walk in the park. Good job on the dash conversion. Another way to do it is to cut across the slotted holes and leave the top part if a person does not want to remove the windshield.
LockDoc
Leon
Old 08-10-2014, 10:40 AM   #15
colgad
colgad's Avatar
I would cover up all the firewall AC holes and go Vintage Air (they include the plate). Works so great and the firewall looks better.
Do what you want but I went back to factory AC on my first restro and regretted it.
Either way you can now have the factory vents!
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 08-10-2014, 10:42 AM   #16
michael bustamante
michael bustamante's Avatar
Good job there.. ive been thjnking about doing this myself. This puts a lil fire under me to get it done!
1967custom
michael bustamante is offline   Reply With Quote
Old 08-10-2014, 11:02 AM   #17
colgad
colgad's Avatar
I have never done this but would it be easier to cut the dash through the holes that are covered by the dash pad then unbolt the sides. Rather than down by the windshield?
Old 08-10-2014, 05:19 PM   #18
WIDESIDE72
WIDESIDE72's Avatar
LockDoc
You may have just rained on his parade...my brother considered this swap years ago.
WIDESIDE72 is offline   Reply With Quote
Old 08-10-2014, 07:34 PM   #19
Jocker64
Ill try to answe everybody's question and comments in one message
Kennuck the advantage of having original equipment is that it looks original, works great, and you WILL have fresh air option, and also truck resale of course.
LOckDoc. I am aware of the challenge and parts needed for this retro, I have all of them and they will be installed just like factory.
About cutting the dash in the slotted part of the dash?? I think that will be just a short cut and a hack job, I'm doing things right, I don't think I would like to buy a vehicle and then find out it was hacked in parts that I don't see? Ill prefer to spend the extra time and get it done right.
Colgad cutting the slotted parts is the easiest way but if you wanted done right ill prefer to spend the extra time, is the same cutting just in different part of the dash.
Wideside72. Thanks and no worries
Old 08-10-2014, 07:45 PM   #20
davepl
davepl's Avatar
Nice work! I'll be curious as to how you handle the firewall. Also about why not just cut the holes in the old dash.
From what I know now, I'd cut the holes and use Vintage air, but if you can get this all working ala stock you're a master craftsman.
Are you going to do the cowl vent and fresh air/recirc functionality?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-10-2014, 08:56 PM   #21
Jocker64
I will cut the right holes and patch what's ot needed on the firewall
The reason of not cutting the dash is because I like things done right and also I really like the look of the orogonal vents.
Yes I will have a 100% original features on the A/C working including the recirculating and fresh air.
All be original and fictional, only part not original is going the be the compressor (original too heavy and too much load for the engine) and the POA valve cause I'm using 134a freon.
Old 08-10-2014, 09:29 PM   #22
davepl
davepl's Avatar
I assume you meant functional and not fictional!
Are you sure about your choice of compressor? Seems almost a shame to do all the really hard work to make it stock and then use a modern compressor.
Sure they're heavy and not that efficient, but it's a small cab, not an Escalade ESV you're trying to cool.
Old 08-10-2014, 09:37 PM   #23
Jocker64
Yes I ment to write functional, damn autocorrect!!!
I just found this aluminum compressor, is physically the same.
And you have the choice to use 12 or 134 with it
Old 08-10-2014, 09:51 PM   #24
leddzepp
Moderator
leddzepp's Avatar
You also need to upgrade to a parallel flow condensor if you are converting to R 134. The OEM designed for R 12 is not efficient enough and you will not get cold air once you are in 90 degree plus temperatures.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-10-2014, 11:13 PM   #25
1972RedNeck
1972RedNeck's Avatar
My '72 would blow 36* air in 100* weather. The only thing I did was adjust the POA valve a smidge for the R134a.
1972RedNeck is offline   Reply With Quote
