Old 08-10-2014, 01:21 PM   #1
DaHos
DaHos's Avatar
Boyd Tank bed fill location?
I am looking for a measurement for the filler neck center line from a fixed point on a swb frame. Im trying to figure out where it would come up through the steel floor in relation to the bed floor ribs. Thx, D'
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 08-10-2014, 04:03 PM   #2
Tinkermc
Re: Boyd Tank bed fill location?
Use a section of flexible hose and make it come up where you want it.
Tinkermc is offline   Reply With Quote
Old 08-10-2014, 04:46 PM   #3
brad_man_72
the boat guy
brad_man_72's Avatar
Measure from the frame holes to know where the fuel filler is on the tank. Measure from the bed holes to know where the filler will be in the bed. No piece of 2" tubing will flex enough more much more than 1/2" misalignment. The tank fill and any kind of gas cap will be almost touching.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 08-10-2014, 04:50 PM   #4
DaHos
DaHos's Avatar
Its an option. Just need enough room for it to center on a rib. Any idea of the clearance from the top the filler to bottom of bed? (tank mounted on bottom of frame rails). Still looking for flush mount fillers also.......
1967 C10 SWB
Old 08-11-2014, 02:11 AM   #5
ItsRandy
ItsRandy's Avatar
I have a Boyd tank. I hope the picture helps. You can see the recessed filler door in the center of the fourth board from the left.
ItsRandy is offline   Reply With Quote
Old 08-12-2014, 12:14 AM   #6
jlaird
jlaird's Avatar
Randy, do you have a close-up picture of that filler door?
jlaird is offline   Reply With Quote
Old 08-13-2014, 11:23 PM   #7
ItsRandy
ItsRandy's Avatar
How's this?
Oops...pictures didn't come through. I'll try again.
Old 08-13-2014, 11:41 PM   #8
ItsRandy
ItsRandy's Avatar
2nd try.
Old 08-26-2014, 11:56 AM   #9
DaHos
DaHos's Avatar
TTT......steel floor anyone?
1967 C10 SWB
Old 11-26-2014, 07:14 PM   #10
DaHos
DaHos's Avatar
Bump......anyone even have a std bed fill tank they can measure? Thinking of just not having it installed and get the bolt in kit and put it where I need it........
1967 C10 SWB
Old 11-26-2014, 09:51 PM   #11
boraxman
Keepin an eye out
boraxman's Avatar
I dont know, but will be watching this thread. I have the same tank but have yet to tackle it.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 11-26-2014, 09:54 PM   #12
DaHos
DaHos's Avatar
Do you have access to the tank to get a measurement from the left side of tank to center line of filler?
1967 C10 SWB
Old 11-26-2014, 09:57 PM   #13
boraxman
Keepin an eye out
boraxman's Avatar
Ya may tank is still in the box, give me a few and I will post it up
ZIP 91351
Old 11-26-2014, 10:14 PM   #14
boraxman
Keepin an eye out
boraxman's Avatar
Just want to make sure this is the measurement youre lookin for...If so 4.5"
ZIP 91351
Old 11-26-2014, 10:31 PM   #15
DaHos
DaHos's Avatar
Thats it!
Confirms what Randy posted above w the wood bed. My measurements showed in needed to be 3 3/4 - 4" to center it on a wood bed slat (as his is off center about 1/2-3/4"). Going to go pull some measurements of my steel floor.
Couple more measurements while you have it around if you don't mind.....neck height and tank width, also is the cap threaded or a twist lock?
1967 C10 SWB
Old 11-26-2014, 10:51 PM   #16
DaHos
DaHos's Avatar
4 1/2" puts it center of a "low" rib which would allow for this.
1967 C10 SWB
Old 11-26-2014, 11:03 PM   #17
boraxman
Keepin an eye out
boraxman's Avatar
Cap is a twist lock
Width is just shy of 26.5"
Neck without cap is 2.5"
ZIP 91351
Old 11-27-2014, 12:06 AM   #18
DaHos
DaHos's Avatar
Looks like with mounting tabs down 3" and the neck at 2 1/4" it still leaves 4"+ from neck to bottom of floor. Plenty to work with....
I thank you much!!
1967 C10 SWB
Old 11-27-2014, 10:22 AM   #19
67c10rustbuket
67c10rustbuket's Avatar
The bed floor cross sill will have to be clearanced for the rollover vent.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
