A/C O-rings
About to start replacing them all so I can vac down the system in preparation for getting it charged. Pulled out my little o-ring kit from LMC and organized them.
There are twenty-four o-rings in this kit! Are there really that many in the system? Are any hidden inside the firewall box, or do I just follow the lines and replace them at every junction? Are there any compression or flare fittings or should everything have an o-ring? Thanks! Dave PS: If there exists a map of where they go, that'd be spanky.
![]() Join Date: May 2010
Re: A/C O-rings
As I recall you bought new hoses and tubes. Mine from Classic Industries had the O-rings installed where needed. I never removed the A/C box on the firewall so I don't have a clue what would be needed there. I don't believe the flare fittings had O-rings. Don't think there'd be a way to use them there either.
Re: A/C O-rings
I had to buy new lines because I had lost a tube nut. Not sure if I ever followed up, but it was stuck in the grommet! Anyway, I have a spare set of rings as a result.
My current issue is I cross-threaded the condenser fitting :-(
![]() Join Date: Sep 2005
Re: A/C O-rings
just match them up no theres not 24 in teh system more like maybe 10
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Re: A/C O-rings
I never counted but there are quite a few.
Don't forget your shrader valves. I put all new o-rings in and ended up with a leak from the low side shrader valve.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Re: A/C O-rings
Check it for leaks at each stage of progress- UV dye doesn't lie, a sniffer can get fooled by various solvents and chemicals. Sniffers are handy, but a dye trace removes any doubt.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
