Where can I buy 1/2 front leaf springs
Looking to buy stock leaf springs for the front of my 1/2 truck. All I can find are for lift kits. What are the stock measurements?
Active Member
![]() Join Date: Mar 2004
Re: Where can I buy 1/2 front leaf springs
Rockauto
I looked on there but which ones do I choose?
bought hd stock rears for my k30 here. prob. more than rockauto, but the different springs are listed
http://www.autoandtrucksprings.com/c...ies-228-1.html |
I'm looking for the 2 leaf, don't those face down instead of upwards? How would I know?
At the body shop.
" That didnt make it any newer " " Dont antique the equipment " |
Or a junkyard.
http://www.sdtrucksprings.com/index....oducts_id=7667
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
Or find a local spring shop they can make you a set.
I have a set from a 1970 that I parted. Stock height.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
![]() Join Date: Jul 2014
#11 | |
But - if you go with the three leaf setup it will help control front axle windup (and the resulting unintended steer inputs) during braking. I would also recommend you run as much caster as possible once you go back together. Like 10 deg if you can. This will help with on center feel and straight line stability at highway speeds, especially if you have a short wheel base vehicle. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
