Old 08-11-2014, 12:50 PM   #1
zplightning
Throttle Linkage - '63 with smallblock
I am looking for the bolt/nut size circled in the attached picture - I've realized my throttle isn't fully opening, and I am missing that bolt - hoping to get that slack fixed with a bolt in there and adjust it from there.
Any help would be appreciated!
zplightning is offline   Reply With Quote
Old 08-11-2014, 03:15 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Throttle Linkage - '63 with smallblock
Looked to be 3/16" Sure your linkage is hooked to right hole on carb?
http://67-72chevytrucks.com/vboard/a...1&d=1377291273
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-11-2014, 03:48 PM   #3
zplightning
I'm pretty sure it is but I'll take another look (and maybe a couple pictures) after work, thanks for the pic!
Old 08-12-2014, 12:06 PM   #4
zplightning
The bolt helped a lot and took out a ton of slack, but I don't think I am getting full throttle still and the secondaries aren't opening on the 4 barrel.
Are there any tricks besides shortening the rod going to the carb? If I tighten it any more, it seems to mess with the idle, and the angle it's at is a bit scary.
Old 08-12-2014, 12:12 PM   #5
jtrichard
can you put up pic of the linkage in the truck? i would like to see the angle your talking about
jtrichard is offline   Reply With Quote
Old 08-12-2014, 01:20 PM   #6
1963c-10
1963c-10's Avatar
Heres a good thread on the throttle linkage.....there are several variants of the cab mount itself also. Although it looks that you have the correct one for a sb v8
http://67-72chevytrucks.com/vboard/s...d.php?t=537569
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-12-2014, 01:39 PM   #7
zplightning
Thank you for that info! I actually just grabbed that picture off of the internet, I will try and post up a picture of mine tonight. Knowing the guy who put the truck together, I'm wondering if I need a longer "arm" off the gas pedal.
Old 08-12-2014, 03:58 PM   #8
WhippinSaw
WhippinSaw's Avatar
Another thread with instructions to make your own linkage
Good luck
http://67-72chevytrucks.com/vboard/s...rottle+linkage
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 08-12-2014, 09:05 PM   #9
zplightning
Alright here's what I'm working with. The angle you see is Peru close to straight, and if I shorten the rod any more I'm worried about it binding. Is there anything I'm missing here?
Old 08-13-2014, 12:48 AM   #10
jtrichard
Well two things the link/rod to the carb is to short and it should be very close to horizontal and the "arm" that you put the bolt in should be much closer to vertical then it is .... then it will work fine
Old 08-13-2014, 11:06 AM   #11
zplightning
Ok, I am going to try and adjust it further tonight now that I have the bolt in there. Thanks for that!
Old 08-13-2014, 12:25 PM   #12
jtrichard
you need to replace or lengthen the rod to the carb adjusting will NOT work right ....it is like 3"+ short
Old 08-13-2014, 12:52 PM   #13
zplightning
Thanks again, I'll see what I can come up with - I really appreciate all the help, this forum is awesome.
Old 08-13-2014, 06:58 PM   #14
63burban
Chevy addict
Just curious ....... Why do you NEED full throttle?
63burban is offline   Reply With Quote
Old 08-13-2014, 07:10 PM   #15
zplightning
I wouldn't say that I NEED it, in fact I rarely get a chance to get out of traffic here, but if you've got it why not have the ability to use it every once in a while?
Old 08-13-2014, 07:14 PM   #16
jtrichard
He cant get ANY secondaries the way his linkage is .... what good is a four barrel if you cant get the secondaries to open????
Old 08-13-2014, 07:14 PM   #17
zplightning
Amen!
Old 08-15-2014, 12:44 AM   #18
zplightning
Want to thank everyone for their contributions to this thread. Here's a VERY rough draft, I've got to shorten the rod a hair and fix the return springs but I took it out and it's much quicker!
Old 08-15-2014, 01:01 AM   #19
jtrichard
that looks a lot better
