08-11-2014, 02:22 PM | #1 |
starving for gas
thought I had a vapor lock problem 63 c20 4x4 on early 70's blazer frame w/327ci bowtie. installed new fuel pump, still runs maybe 15-20 miles and then starves for gas, then installed new red holly electric pump, new canister filter before pump, and a pressure gauge right after a see thru filter near carb, 4 1/2 lbs fuel pressure at carb, then ran for 15-20 miles and same problem, no fuel pressure and see thru filter empty. I see the fuel line coming out of behind seat gas tank is on top? How does this work, is the pickup inside fed by siphon? Seems to me if it's gravity fed to pump, fuel line would come out the bottom of tank, oh yes, I installed the holly pump right under the tank. plus, seeing how it's not the fuel pump, can I run the mechanical pump, with the holly electric still inline, but turned off? (holly is kinda loud)
08-11-2014, 02:45 PM | #2 |
Re: starving for gas
check the fuel line routing, it seems like you may be getting vapor lock. Make sure fuel line isn't close to exhaust or engine components. Fuel pump should have enough suction to pull fuel from the tank it is not a gravity feed. You may want to sending unit from the tank and check the sock on the end of the pick-up crud if the tank is old.
08-11-2014, 02:50 PM | #3 |
I would suggest to remove the Holley pump and pre-filter before the pump. Mechanical pump probably will not pull fuel through those items.
08-11-2014, 02:52 PM | #4 | |
08-11-2014, 02:57 PM | #5 |
oh, ok, so you suggest removing the canister filter that is installed just below the gas tank, and before the mech. pump, and not route the gas line thru the electric pump if I'm using the mechanical pump,right?
08-11-2014, 03:11 PM | #6 |
I would remove the filter and pump because it may not be a regular service item for you. I also don't know what the flow rates is threw your filter. I stock pump doesn't like to suck fuel real well with a lot of restrictions. Electric pumps push fuel real well that is why the manufacturers recommend putting the pumps close to the tank and use a pre-filter to protect the pump.
the stock pump should provide adequate fuel. Only other option I would pursue would be to remove the mechanical pump and just use the electric. Even mounted with the supplied rubber biscuits they are still loud. I use to run two Holley blue pumps on my 72 Z28 with a BBC The dual Flow masters helped cancel out their noise. |
08-11-2014, 03:29 PM | #7 | |
08-11-2014, 03:40 PM | #8 |
just one last thing I would check is the vents for the fuel tank/or cap. If it is not properly vented it my give you problems. what pump are you using? are you using a pressure regulator? Pump pressures will vary with temperature. Too much pressure and you will have float problems. I like to keep pressure set around 5-6 psi
08-11-2014, 07:08 PM | #9 | |
