08-11-2014, 03:10 PM | #1 |
Junior Member
WTB: Complete rear axle assembly, 4x4, 3.73
Anyone within driving distance of Seattle have one? My '72 K5 rear diff blew up and took out the housing. I'd like to just swap in a replacement rear end. Need 3.73 gears but may consider something else to get by. THANKS!!!
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
08-12-2014, 03:43 PM | #2 |
Junior Member
Re: WTB: Complete rear axle assembly, 4x4, 3.73
Ttt
08-12-2014, 09:36 PM | #3 |
73 to 80 will work if you don't mind moving spring mounts and shock mounts
08-13-2014, 02:42 PM | #4 |
Junior Member
Yea there are many options if I want to do spring perches and stuff. Giving this a shot first.
08-13-2014, 02:56 PM | #5 |
Member #1049
Jared,
If you do not find a bolt in. I have a 3:73 out of a 72 4x4 Blazer that had the spring perches moved for a 2WD conversion and 5 lug axles/drums installed. (the shock mounts are still in the original location) |
08-14-2014, 12:18 AM | #6 |
Here is a posi unit with 3:73 gears. You can have the whole rolling frame for $900.
http://67-72chevytrucks.com/vboard/s...d.php?t=615806 |
08-14-2014, 02:29 PM | #7 |
Junior Member
Thanks Mark. Wouldn't that be ironic - still doing fab work to restore the perches.
John, this could work. I'll reply to your post.
09-20-2014, 10:32 AM | #8 |
Junior Member
Still searching
03-06-2015, 03:31 PM | #9 |
Junior Member
ttt
05-04-2015, 01:12 PM | #10 |
Well, I know I am not close (only 1100 miles down I-90), but I have a leaf spring rear end out of a 69 4x4.
It is a TQ 11 06 W 2
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 05-04-2015 at 01:18 PM. |
