08-11-2014, 04:00 PM | #1 |
If you have your cab off can I get a measurement??
Hey guys, I'm sure many of us have our cabs off, I just need a measurement from the center of the front cab mount to the center of the rear cab mount. just finished shortening the frame and the paper I had with the measurements got destroyed and is unreadable. Thanks in advance.
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion |
08-11-2014, 04:07 PM | #2 |
Re: If you have your cab off can I get a measurement??
On my 72 C-10 short stepside, I get 41 3/4 " from the centerline of the front cab mount to the centerline of the rear cab mount. Hope that helps.
08-11-2014, 04:08 PM | #3 |
Perfect thanks. I lookex at just moving the moumt back 12 inches but I wanted to be sure
08-11-2014, 04:19 PM | #4 |
No problem...glad to help...good luck with your build !
08-11-2014, 04:21 PM | #5 |
Yah, I was spot on. 12 "back from the original puts me right at about 41 3/4. :-)
