Old 08-11-2014, 05:13 PM   #1
ccstevejr
motoheader
got 83 Chevy K10 with 32 in. tires n 4in. lift...was told anytime u use over-sized tires u need to change rear-end gear ratios I assume to a higher? ratio...how do I know what ratio gears I'm runnin now?...do u believe I need to change ratios?...mayb I already have the right ratios in both differentials...any feedback on this would b appreciated...tankz ..."motoheader"
ccstevejr is offline   Reply With Quote
Old 08-11-2014, 05:39 PM   #2
Nin92
Nin92's Avatar
Re: motoheader
I've always just popped the differential cover. It's stamped on the ring gear. If it's not you can always just count the teeth. You don't have to change the gears but if it's a high gear ratio it will be a dog off the line. I believe most 4x4 models came with 3.08, 3.73 or 4.11 gears stock.
Nin92 is offline   Reply With Quote
Old 08-11-2014, 05:47 PM   #3
donut
donut's Avatar
Re: motoheader
32" is not an overly tall tire. How does it feel? Does it lug on take off? How tall were the stock tires?
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 08-11-2014, 09:25 PM   #4
ccstevejr
Re: motoheader
know none of the above because bought it like it is n am workin on it...haven't even got engine runnin yet and transfer case short shaft hooked up...tryin to simply "lQQk down the road" sort of speakin less I run into any future probz...do u kno how to figure what gear ratio I mite hav?...really appreciate the come-back... kudo's:waah
Old 08-11-2014, 11:03 PM   #5
mrolds88
Re: motoheader
I had a 86 K10 305/ 4 speed with 3.08's and I went to 32s. Never an issue.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 08-12-2014, 06:10 AM   #6
ccstevejr
Re: motoheader
OK, thanks...dunno where I'm getting all this wrong info from on the web...also heard that over-sized tires would send my early 1983 TH700R4 to itz grave, since the earlier onez (TH700R4's) were too weak for runnin over-sized tires...comment anyone?...when did they start makin the "better" TH700R4's?... motoheader (nick-name) thankz guyz!!
