08-11-2014, 08:57 PM | #1 |
Repair a Damaged Speedometer?
The speedometer was damaged, is there any way to economically repair a speedometer in this condition?
The face of the speedometer was crushed and broke the needle off as well. Is it possible to swap faces for another face and re-attach the needle? Is this a lost cause and more trouble than its worth to repair? It is a shame, because the face was in excellent condition. Thanks |
08-11-2014, 11:33 PM | #2 |
Re: Repair a Damaged Speedometer?
Your best bet it to poke around the Parts Board for a different one. It's going to be cheaper than having that repaired. If you want to become a Premium member you could post a Wanted to Buy.
Good luck.
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
08-11-2014, 11:55 PM | #3 | |
The Older Generation
Let me see what I have. If I have a decent one you can have it. All you need is the face and needle, right? I will check in the morning. LockDoc
08-12-2014, 12:10 AM | #4 |
Thanks LockDoc
Yes I think all I need is a face and a needle. |
08-12-2014, 08:38 AM | #5 |
Cluster King
If LocDoc cannot help you let me know.
I can repair what you have there or sell you a replacement. I can also calibrate it and make sure it works good for you. Take care, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
08-12-2014, 09:23 AM | #6 |
I have what you need. PM me your address. LockDoc
08-12-2014, 10:39 PM | #7 | |
When you say calibrate, do you mean calibrating the speedometer to read accurate speed? I recently replaced my speedometer with one from a 4x4 Suburban and now it is off 6 mph at 55 mph. I changed the speedometer cable at the same time. It has left me a bit confused as I thought the calibration was done using the driven gear in the transmission. Can you shed any light on this? |
08-12-2014, 11:15 PM | #8 | |
Cluster King
08-13-2014, 02:20 PM | #9 |
Parts sent. LockDoc
