Old 08-08-2003, 11:57 AM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
84-86 Camaro alternators
I scored a brand spanking new Camaro alternator off ebay for $15. I had it tested for free at Parts America just for security. Well, I installed it yesterday. WOW, I like the difference between the 94 amp alternator and the stock 66 amp. I could tell the difference right way. Mostly with the power windows. The extra amps sure do make a difference. Now I just need to lube the window brackets again the windows should roll up and down easily. The voltage is also more consistant between idle and cruising. If anyone has power options in their truck try one of the 84-86 94 AMP alternators. It has a max output of 107 amps too and they are direct replacements. All the wiring is the same. Now I just can't wait to install the electric fans. I just need some ramps to get the coolant out.
I have pictures is anyone is interested.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
