help with rear cab support
getting my but kicked trying to install a rear cab support, any tricks to this. also should i brace the cab before i remove it. thanks for the help.
![]() Join Date: Jan 2011
Re: help with rear cab support
Should brace the cab before any floor surgery. At the minimum leave the doors on and shut.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
What exactly is giving you trouble?
I think most of the problem is an ill fitting reproduction. I have a wrecked donor cab with a good support in it. I am going to cut that out and try that. getting away from it for the weekend might also will help. I am also trying to do it with the cab on. wanted to restore the cab integrity before removing it. I cut the old one off about half way up and am trying to butt the new one to it. Installing all new rocker inner and outer and front lower pillar and cab corner
Ah, I went through much of the same. The repop rear cab supports I received required a fair amount of rework. I also installed them with the cab on the frame.
Starting here: http://67-72chevytrucks.com/vboard/s...6&postcount=25 ![]() It all turned out well though, at least IMO. ![]() |
Nice job, it looks good.
#7 | |
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Thanks guys. You'll see in my build thread that the cab was braced and panels were zip-screwed in place after setting the door gaps but prior to welding the floor panels and rockers. I tightened up the door gaps, particularly at the rear, a bit from stock.
