AC Problem
My evaporator iced up with the blower on low speed. When I put it on high the ice cleared up. Does anyone know what the problem is?
Re: AC Problem
Usually low on gas (r12 or 134)
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Re: AC Problem
You need to put gauges on it, it could be one of 3 things, low on air flow, low on gas or metering device not feeding properly.
Re: AC Problem
It does get real cold. Cools down when outside temp is 100.
Re: AC Problem
Prolly low air flow then, check filter if it has one.
