Old 08-12-2014, 07:34 AM   #1
Coursey
Coursey's Avatar
Trim Restoration?
Has anyone tried to restore the trim on a 71-72?
The trim itself is in good shape, but the black is faded out.
New trim kits are $850. So I figured it is worth a shot to restore?
Coursey is offline   Reply With Quote
Old 08-12-2014, 07:41 AM   #2
Bhelton
Bhelton's Avatar
Re: Trim Restoration?
I stripped, polished and redid every piece of mine. Just takes time
Bhelton is offline   Reply With Quote
Old 08-12-2014, 07:54 AM   #3
Coursey
Coursey's Avatar
Looks good!
What did you strip it with?
Old 08-12-2014, 08:15 AM   #4
Bhelton
Bhelton's Avatar
I used 100% lye from lowes and gray scotch brite, if you go that route just good rubber gloves and do it in a well ventilated area.
Old 08-12-2014, 08:34 AM   #5
Coursey
Coursey's Avatar
How did you do the black?
Tape off the areas and spray?
Or spray all black and use thinner to remove from high spots?
Old 08-12-2014, 09:28 AM   #6
boraxman
Keepin an eye out
boraxman's Avatar
Ya I dont understand why the repop trim kits are so expensive..
I looked at some places online that do restoration but it doesnt cost much less/
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 08-13-2014, 01:14 PM   #7
48richard
48richard's Avatar
I just did mine. I stripped the old anodizing with lye (5% by weight solution) for about 45 minutes, which also took off the old black paint. The next step was to sand with 320 grit and polish it on the buffer. I then clear-coated it, and used black tape instead of paint.
I know that tape was not correct, but since the woodgrain ones were taped it didn't seem too much of a stretch.
I'm pleased with the result, and have about $100 in it, including buying the 12 pieces of trim from guys on the forum.
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 08-13-2014, 07:03 PM   #8
engineer_gregh
engineer_gregh's Avatar
Richard can you post some close up pictures of your trim after your restoration? Good thread and thanks for posting it Coursey.
engineer_gregh is offline   Reply With Quote
Old 08-13-2014, 07:54 PM   #9
48richard
48richard's Avatar
Here you go.
There are some small bubbles in the clear, but I judged that to be OK for a driver.
I needed two widths of tape - 3/8" and 1 5/8" - and what I ended up with was too glossy, so I painted the tape with vinyl coating which gave it a nice satin finish. Still much easier that masking and painting the moldings, though.
Old 08-13-2014, 08:55 PM   #10
Thebrownturd
What kind of tape did you use?
Thebrownturd is offline   Reply With Quote
Old 08-14-2014, 08:55 AM   #11
engineer_gregh
Looks good. Thanks for posting Richard.
Old 08-14-2014, 11:59 AM   #12
48richard
48richard's Avatar
The tape was 3M trim tape.
Old 08-14-2014, 02:04 PM   #13
hoovers71
can you provide a link for the tape? Only can find the tape that is an adhesive by 3m. Looks great btw, I am inspired to do it that way.
hoovers71 is offline   Reply With Quote
Old 08-14-2014, 02:14 PM   #14
48richard
48richard's Avatar
I purchased it here;
www.lettersunlimited.com
The 1 5/8" tape, which is what you need for the center stripe, was on their "odd lots" page, so may not be a stock size. I got lucky for $10
Old 08-14-2014, 02:24 PM   #15
hoovers71
thanks. what is the width of the narrow striping?
