08-12-2014, 09:04 AM | #1 |
Low hump cab and T56 trans- will it clear?
wondering if anyone out there with a T56 trans has a low hump cab and if they had to massage it to fit. thanks
08-12-2014, 11:21 AM | #2 |
Re: Low hump cab and T56 trans- will it clear?
It will be veryy tight...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-12-2014, 02:35 PM | #3 |
Mine did but yes it is very very tight. I thought about replacing it with a high hump but don't know that it would gain me anything.
It is so dependent on motor mounts and their locations. My motor is as far back and as low as I could get it with my custom mounts.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
08-13-2014, 06:43 PM | #4 |
thanks fellas- guess I'll put the motor/trans in first, then put the cab on without the hump and go from there.
08-14-2014, 10:21 PM | #5 |
I have a T56 and low hump 65 cab. It is tight but works well. I moved the shifter up to the inspection port and let the housing stick up thru the floor a little. Covered up by the shifter boot. The transmission housing has about 1/4 inch clearance with the cab floor. Should be a little more room if the shifter is in the normal rear location. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
11-16-2014, 03:14 PM | #6 | |
11-16-2014, 09:11 PM | #7 |
I am running the original bench seat. I moved the shifter location forward in the transmission so I could do that otherwise it comes up under the seat. See my build thread for pictures.
TR
