Do you know where the sensor on the second pictures goes, I had a minor accident, the headlights broke and I found that sensor just haging, the sensor on the first picture was still in place. Also, are those for the air bags??
Thanks ![]() ![]() |
Re: What are these sensors
Ambient temp sensor, For the exterior temperature display
The impact sensor(or sensors depending on year) are mounted to the bottom of the core support. If you were in an accident that caused any of the airbags to deploy, or any of the seat belt tensioners to deploy, You will have to replace those components, and the impact sensor, ands the SRS control module. |
thanks, so where would the passenger side sensor be attached to.
no air bags were deployed, and the seat belts work fine. |
headlamp mounting panel near the bottom
