![]() Join Date: Aug 2009
Wrong Dropmember Motor Mounts?
Hi, I'm not new to the site, but I'm new to asking questions. I have a 64 GMC Suburban, some mechanical skills, but no where near to what a lot of you guys (and girls) have! This site is so informative! I can usually look for an answer here and find them, and I have A LOT of them. I would like to start a build, but don't want it to be too long. I started the teardown in 2009, purchased Porterbuilts v3.2 Dropmember and rear extreme kit and was on my way. I originally was going to put an ls-1 in but am going with a 350. I bought different motor mounts from a member here and this is where I'm at. Since then I have moved and put it on the back burner. If it wasn't for this site and the Unbelievable trucks, I would have probably sold it. So I PROMISED my children that it would be finished this winter. I'll post pictures up later and possibly start a build thread. the question that I have now is, do I have the wrong motor mounts??? The angle of the motor seems too much, if I put the tranny on it would hit the ground. Tell me what you think ? THANKS soo much for your help!!!! Jeff
![]() Join Date: Jan 2011
Re: Wrong Dropmember Motor Mounts?
Get with Nate from Porterbuilt and he will be the best one to figure out what it is you have.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Sorry, tryinb to figure how to upload pictures
Put the tranny on it and set the rear mount. The engine is going to lean way back like that if not supported in the back. It should look a lot better after that.
Jimmy
and if the motor is lifted in the back it hits the steering rack
another picture
maybe your engine side mounts are in the wrong (front holes) putting it to far forward get some pics of the mounts so we can see more of what is going on
motor mounts
Thanks for your help Richard
67-72 parts collector,…
![]() Join Date: Nov 2002
Talk to Nate Porter.
Looks like you need the inner frame gussets also.
Thanks Keith, do you happen to have a picture of the frame gussets?
since you dont have factory mounts my first idea is out the window...one of 3 things is wrong #1 engine is too far forward #2 engine is too low #3 rack is too high or too far back ...without the body on it is hard to tell just what is going on..... maybe someone with that same (rack/mount)setup can help with measurements
#13 |
Here you go,...
#14 | |
Thanks! Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#15 |
Hey Keith, first of all, Thanks for all your help. My dropmember is a v3.2 if that matters? It looks a little bit different than the one in the photo you sent. Did the other mounts change at all from kit to kit ?
#16 |
Thanks so much Nate! I will as soon as I get home.
#17 | |
Top notch customer service from the Nate at Porterbuilt!
