Old 08-12-2014, 05:01 PM   #1
jh68c10
fuel tank for ls swap
Can I still us my stock tank with LS engine. If not is there another inexpensive option.
jh68c10 is offline   Reply With Quote
Old 08-12-2014, 10:31 PM   #2
Fitz
Re: fuel tank for ls swap
The LS engine requires a high pressure electric pump in the tank, an inline filter regulator(see pic) and a high pressure return line , but yes, if you install the fuel return bung and line into your existing tank you can use it. Good luck finding someone who will weld that bung in, though. That's a really good way to end up in a grave. It is safer to find an aftermarket tank set up for the LS engine or get a tank out of a later model truck that is already equipped that way.
Fitz is offline   Reply With Quote
Old 08-12-2014, 11:22 PM   #3
Robznob11
Robznob11's Avatar
I got a 2002 camaro tank with pump for 100$ it will fit under the bed behind axle with minimal work. Let me know and I'll grab some pics for you. Basically just have to remove the small bar on the top rail and move the rear frame member back a little trim a little off the BOTTOM of the frame rail and drill a hole through the frame for the filler. Then just mount it up with a couple pieces of aluminium strap from the hardware store
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 08-12-2014, 11:38 PM   #4
trkfrk
trkfrk's Avatar
I found an old boat tank, added a baffle, made my own bung and welded it in. All you need is a couple of hole saws and a TIG welder.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 08-12-2014, 11:42 PM   #5
trkfrk
trkfrk's Avatar
Pic 2
Mark
Old 08-13-2014, 06:08 AM   #6
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
I like that tank!
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 08-13-2014, 12:44 PM   #7
joesgreen67
joesgreen67's Avatar
I used a jeep wrangler tank
joesgreen67 is offline   Reply With Quote
Old 08-13-2014, 12:52 PM   #8
boraxman
Keepin an eye out
boraxman's Avatar
Im using the stock in cab tank with an external electric fuel pump on a stock 5.3 set up and is working fine.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
