08-12-2014, 10:55 PM | #1 |
Engine Id help
Hey all kind of new here been lurking for a while. I finally got to start working on my acquisition 1966 long fleet c10. I need help identifying the engine. The intake casting is. gM 3823418. Any body have any clue. It has a single barrel carb I know it is an inline six. Thanks
08-12-2014, 11:02 PM | #2 |
Re: Engine Id help
I think you will need a casting # from the engine block itself to find out.
1982 K10 SWB 1987 V20 - Sold - Doh! |
08-12-2014, 11:09 PM | #3 |
Re: Engine Id help
Here is a pic of the drivers side of the engine.
08-12-2014, 11:25 PM | #5 |
Re: Engine Id help
Block casting number is on the right/passenger side of the block, BTW.
08-13-2014, 10:25 AM | #6 |
Re: Engine Id help
Can you post a pic of the other side of the engine? I could tell you which engine it is right off the bat if you can.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
08-13-2014, 11:46 PM | #7 |
Re: Engine Id help
How can you tell from that side of the block?
1965 C10 Project |
08-13-2014, 11:51 PM | #8 |
Re: Engine Id help
Looking at the oil pan I'm actually kinda sure its a 292...won't know for sure till I see the side covers.
08-14-2014, 12:21 AM | #9 |
Re: Engine Id help
I will post a pic tomorrow when I get a chance to go work on the truck. Thanks for the input
08-14-2014, 12:41 AM | #10 |
Re: Engine Id help
The block having the 1.75" taller deck height moves the head and everything attached to it up, and the 292 also has that bypass hose coming off the waterpump.
08-16-2014, 01:02 PM | #13 |
Re: Engine Id help
Thanks It is a 292. Just finished installing some pick and pull dodge Durango rear bench seats . Now on to rebuilding the carb, new points and plugs.
