Old 08-12-2014, 11:53 PM   #1
Sean C
Decreasing Turning Radius?
Has anyone decreased their turning radius? My truck has an Ididit steering column. Its radius right now is ok, but parking can be a bit of a pain. As my DD, I definitely wouldn't mind a smaller radius. Thoughts/suggestions??
Sean
Sean C is offline   Reply With Quote
Old 08-13-2014, 08:29 AM   #2
McCoyAZ
McCoyAZ's Avatar
Re: Decreasing Turning Radius?
And all this time I thought it was just me that had to back up and turn a few times to park....and mines a short bed.
McCoyAZ is offline   Reply With Quote
Old 08-13-2014, 08:43 AM   #3
davbowen
davbowen's Avatar
doesn't the stops on the spindles control the turn radius.
davbowen is offline   Reply With Quote
Old 08-13-2014, 10:28 AM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Yes, the spindles have a point that contacts with the lower control arm bump/steering stops. Unless you remove this stop off the lower control arm, you will not get any more steering angle.
The column has nothing to do with steering angle.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-13-2014, 10:34 AM   #5
LVPhotos
LVPhotos's Avatar
Left foot brake, right foot gas! I have come in hot and power slid into spot next buddies car.
Quick ratio box or rack will do. My open knuckle 56 Willeys Jeep turned tighter than car with rack.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-15-2014, 12:43 AM   #6
Sean C
Hahaha I like this idea! Alright thanks for the input all. I'll let you know how everything goes when it's done.
Sean
Old 08-15-2014, 12:58 AM   #7
66Submarine
66Submarine's Avatar
I guess you'd probably really like driving my 133" wheelbase C30 in a crowded parking lot!
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 08-25-2014, 09:18 PM   #8
19666Trucker
19666Trucker's Avatar
Cut my bump stop out when lowered the on 66 3/4 lbw, now my tires hit frame but it can turn real tight, backing up it is like folk lift .
19666Trucker is offline   Reply With Quote
Old 08-26-2014, 09:30 AM   #9
McCoyAZ
McCoyAZ's Avatar
I drive a 35' 13 ton truck all day long and that's all the fun I can stand for the day.
