Old 08-13-2014, 12:15 AM   #1
Wilkrsn
Need lowering help...
I lowered my c10 awhile ago, the wrong way. Now I'm going back the correct route but have no Idea how low the front of my truck is. It's a flip kit out back, but the front is just cut springs. It's on the bump stops and needs to be brought off them so I can correctly align the tires. I'm just ordering spindles and springs, and I dont know if I should go with 3in drop spindles and 1,2, or 3 inch drop springs.
Front: 255/35/20
Rear: 275/40/20
Wilkrsn is offline   Reply With Quote
Old 08-13-2014, 02:16 AM   #2
tinydb84
tinydb84's Avatar
Re: Need lowering help...
Go with 3 inch spindles. Get a set of stock springs and cut a coil or go with one inch drop and trim half a coil until you get the height you like.
David
Instagram: myfabguy
Old 08-13-2014, 08:48 AM   #3
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
I second that.
Mine was 2.5" spindles and 2" drop springs. If I were doing it again, I'd skip the springs and just trim my stock ones until I was happy.
killthewabbit is offline   Reply With Quote
Old 08-13-2014, 10:32 AM   #4
IIGW
air-ride. it'll solve all your problems, it's adjustable, and youll be happier.
IIGW is offline   Reply With Quote
Old 08-13-2014, 01:06 PM   #5
77c10
77c10's Avatar
Nice ride, welcome to the forum!
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 08-13-2014, 01:19 PM   #6
Rich84
Rich84's Avatar
If you are on the bump stops..Your really low. I would go with 3" spindles and 1.5 drop springs. That should get you off the bump stops (remove the rubber).
Rich84 is offline   Reply With Quote
Old 08-13-2014, 07:10 PM   #7
Wilkrsn
I put it on some of the smaller triangle bump stops instead of the big box stops, and it sits on those so... I just ordered 3' drop spindles and some 2' springs. I got a good deal on the springs, I have a really good set of stock springs if they dont work out to cut down, gonna see where it goes from there. I'll post an update of how it goes this Saturday, here is the truck after I put the old rally's back on it so I can get it to the shop without a trailer. Thats my grandfather on the left if you're curious haha.
And I would love air-ride. But thats even more money. Maybe down the road.
