![]() Join Date: Mar 2011
all plus shipping
x member very clean $25 TH350 mount very good $8 cooling lines and vacuum modulator line $25 one piece driveline, rebuilt has maybe 10 miles on it before I lunched my trans and went with a different configuration. was behind a TH 350 in the 6 cylinder position so should be correct for a V8 with a 700R. I will get a measurement tomorrow $175
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
Re: x-member, mount, lines, Driveshaft 700r?
lines
mount
Whats that gauge in the box?
1967custom |
That there is one of these here:
![]() Join Date: Oct 2013
What would be the crossmember cost shipped to 21921?I am putting a nv4500 in and have nothing now but the old riveted in 3speed manual one.
I will get the measurements when I get home. Figuring 20 pounds, 30x6x8 is cheapest at $24.54 I think that is pretty close...
Oooh mooneyes. I wish i needed that.
1967custom |
Im looking through all the nv4500 posts and threads to see if this cross member will work for me .If any one knows please let me know.Thanks.
can you post a picture of drive shaft?
1953 Chevy 3100 1964 Chevy Impala 1966 Chevy El Camino 1970 Chevy C10 Fleet Long 1972 Chevy C10 Step long 1985 Chevy K10 Fleet Short |
driveshaft center to center of the u-joints is 56", with the yoke (allowing 3/4" play) 58".
So centerline of differential u-joint flange to end of output shaft of your trans should be about 58" give or take a bit.
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 Last edited by DesertCat; 08-16-2014 at 12:36 PM. Reason: measurements added |
#13 |
yoke is in great shape to... no noticeable wear
#14 |
interested, please put me on first.. can you provide shipping cost to 44288? in the mean time I will do some measuring...thanks
#15 |
Looks like $60 Fedex ground
#16 |
unfortunately this is not going to work for me...too short. Thank you..
#17 |
