No bumpstops from the factory? Step inside Keith Seymore
I picked up a 78 GMC a couple of days ago which appears to be mostly original with no evidence of ever being lowered. While crawling around under the truck I noticed it has no bumpstops front or rear, it doesn't even have the old rivet holes on the frame or remnants on the lower control arm of it being cut off. I'm curious if any one else has ever seen one without them or if there is a bumpstop delete option.
John 82 Chevy Silverado 350ci/TH350 ![]() |
Re: No bumpstops from the factory? Step inside Keith Seymore
I'm not aware of a "bumpstop" delete option. Truck appears to be a 1/2 ton 2wd short box from the photo?
Could be a manufacturing mistake but that seems like it would only affect one corner (ie, not both control arms AND both sides in the rear). Can you post some pics? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
She's ready to go down..
![]() Join Date: Jan 2012
#5 | |
Fear not....it will be going down and Im glad they are missing because they would be removed anyway.
John 82 Chevy Silverado 350ci/TH350 ![]() Last edited by J Knight; 08-13-2014 at 07:00 PM. |
At the body shop.
Nome of mine ever had front bumpstops after dropping the front. I wouldn't be concerned
" That didnt make it any newer " " Dont antique the equipment " |
It wasn't a concern just a curiosity, I've never seen one without them.
At the body shop.
You can drill the spot welds out. They leave almost no evidence behind on the A arm.
And when tried the pre runner thing with my '77 and you stuff a 32" dueler into the fender... It's all bad. But never seen one missing all 4.
