Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 08-13-2014, 09:22 AM   #1
84rzv500r
a couple questions for my c- ?? project GMC^2
Amazing amount of knowledge here... spent a few hours searching but need some help...
A jimmy with a jimmy 8...
1) has anyone used a set of Milemarker 11166 lockouts on a Napco 2.5 ton front axle? I need to pull the stub axle flange off to check the axle dia (1.75") and splines (34) but at 5.080" bolt circle it matches up superficially. The napco shop manual is a little light on the big axles.
2) what year did the big chevy's convert to a hydraulic over dual line brake system? It seems a little vague to me.
3) did any years use a hydraulic slave cylinder on the clutch? I am really tight on room in the foot well for mechanical linkages. I have a good single MC that I am gonna use as a clutch master if I can work out a mounting and a linkage.
4) this truck is door tag rated at 24,000 GVWR with 7000 front and 17,000 rear but it has optional 9000 lb front springs and 34,000 lb heavy frame/rear spring (no helpers though) according to the build sheet in the glove box. What do I call it? I think it is a C-55 as I have a C-50 Chevy and a C-65 to compare it to for parts...
72 GMC K5500 Napco 4x4 8V71/RTO-9513/T-1138
71 Corvette Wide Body 502 Ramjet
83 HD XR1000, 99 HD XL1200S, 84 YAM RZV500R
05 MB E55 AMG, 12 45th Camaro SS stick vert
84rzv500r is offline   Reply With Quote
Old 08-13-2014, 01:52 PM   #2
mrolds88
Re: a couple questions for my c- ?? project GMC^2
In answer to your clutch issue, the answer is yes.
http://www.ebay.com/itm/New-Bendix-B...efb353&vxp=mtr
There is the master. Haven't run across the slave yet.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 08-13-2014, 09:17 PM   #3
84rzv500r
interesting... i have done some more research and think i will go with a 1987 C-60 Drum/Drum master and Hydroboost (not HYDRAVAC) and then move my c-50 brake master over to the clutch and use a Wilwood slave cylinder on the linkage at the frame...
Old 08-18-2014, 01:13 PM   #4
84rzv500r
I think i am figuring this stuff out... I am gonna use a little literary license and call my truck a K-5500... I have fender badges that say GMC 6500 V8 from my '72 c-6500 427 parts dump truck that I am gonna use just for fun...
