Old 08-13-2014, 10:57 AM   #1
burb71
Active Member
Help please! Need a pic
Can you guys with factory Aux Battery and or factory Tach please post pics of where the Harnesses inters the firewall.
I have a 1968 and its different from the factory placement pics Ive seen on 1971-72 posted pics
burb71 is offline   Reply With Quote
Old 08-14-2014, 09:16 PM   #2
burb71
Active Member
Re: Help please! Need a pic
ttt
Old 08-17-2014, 05:21 PM   #3
SS Tim
SS Tim's Avatar
T t t
SS Tim is offline   Reply With Quote
Old 08-17-2014, 09:05 PM   #4
MusicMan70
MusicMan70's Avatar
Not sure if this is the one but it's from a 70...bit blurred but is it the red wire right of the main harness.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 08-17-2014, 09:11 PM   #5
aventur1
aventur1's Avatar
I've watched waiting for an answer here. I have one, although it's in the body shop in another town in Melba, Id. The guy is originally from Portland area with a mega custom shop and just wanted to give up the big city life. Customers send high dollar work to him from Portland, Cali area to Melba for him to do work on there cars. Can't wait to see mine done, body work and primer only for now.
Don't give up, wish I could get a photo for you to help out. But it's a week and a half out before I get it back. There is a hole for it if I remember looking from the front it is about 3 o'clock position off dist, I think.. Sorry not much help now but will glade to sent a pic when I get it back. Of course will be sending pic when all said and done....
1968 4x4 Frame, with a 67 Cab and Bed
A Shorter Step
1999 Dodge 2500 Cummins Diesel
aventur1 is offline   Reply With Quote
Old 08-17-2014, 09:14 PM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's a pic (borrowed, thanks Mel) of the tach hole, which IIRC is 3/4" diameter. Aux battery hole is drilled through the dimple just below this and is same diameter.
Edit: to clarify this is correct for 72, not sure for 68
Old 08-18-2014, 10:37 PM   #7
burb71
Active Member
If your 68 has the factory Aux battery I would very much like to see a good pic of the spot the harness enters the fire wall, after you get you truck back.
did it come with a Tach?
Old 08-18-2014, 10:41 PM   #8
burb71
Active Member
Thanks for posting a pic, but 68 fire wall is a little different.
Old 08-18-2014, 10:47 PM   #9
burb71
Active Member
One pic I found of a 71 or 72 seemed to show the aux batt harness grommet close to the emergency brake cable grommet, but they changed from hand pulled emergency brake to foot pedal type in 1969, so I think they relocated the spot the cable enters the fire wall.
Old 08-19-2014, 07:35 AM   #10
aventur1
aventur1's Avatar
burb71
no aux battery, and ya I'll get a pic for you on the tach location..
A Shorter Step
Old 08-19-2014, 09:40 AM   #11
burb71
Active Member
burb71
Ok I had it backwards, you have factory tach, no aux Battery.
I do very much need pic of 1968 tach harness location also.
Thanks, Steve
Old 08-19-2014, 12:19 PM   #12
aventur1
aventur1's Avatar
burb71
Ok will do.....
A Shorter Step
