08-13-2014, 01:51 PM | #1 |
Gas Tank Seeping
I finally got the fuel sender working on my 61 Panel, and I was able to confirm that I am loosing fuel. It doesn't leak enough to drip, but it seems that its seeping from the tank. The previous owner fixed several pinholes in this tank.
Should I just replace the tank, or is there a solution to fix the one I have? Tanks for these are so hard to find without spending hundreds on a custom built one. |
08-13-2014, 03:00 PM | #2 |
Moderator
Re: Gas Tank Seeping
There used to be a franchise called Mr Gas Tank that took an old tank, and coated it inside and out with some sort of epoxy (?) to seal it. I had this done on my 71 Pontiac over 20 years ago, and that tank still holds gas without a leak (and looks brand new). Try googling for something like "gas tank sealer" and see what you can find. Old fashioned Yellow Pages might help, too!
You want some place like this: http://gastankexchange.com/products-services/ Last edited by jayoldschool; 08-13-2014 at 03:11 PM. |
08-13-2014, 03:18 PM | #3 |
IMHO, a seeping gas tank presents the greatest risk of fire, even more so than a leak. The reason being is that what readily ignites are the fumes from gas. Seeping gas creates a great environment for the creation of fumes. Get rid of that tank! You're driving in a bomb that's ready to blow.
08-13-2014, 06:48 PM | #4 |
Replace it. You can't seal over rust.
08-13-2014, 07:00 PM | #5 |
A new tank is cheaper than a burned up truck. I put a new tank, sending unit and replace all rubber fuel lines in every truck I rebuild.
08-13-2014, 08:18 PM | #6 |
Replace all fuel filters too.
08-13-2014, 08:25 PM | #7 |
there is a sealer that I used on an 67 dually that i had and believe it was called POR 15. Check with your local auto parts store. It is a little bit of a process but my tank had lots of seeping pin holes and it worked great!
Only stuff I would ever use if I had another tank that needed sealing. Great stuff!!! |
08-13-2014, 08:34 PM | #8 |
I ended up finding a Blazer tank kit today. I'm going that route.
Thanks for the replies. |
