Old 08-13-2014, 02:29 PM   #1
Sweet Willy
Sweet Willy's Avatar
odd question... maybe
I'm looking at a '63 step-side. What I want to know is what are the dimensions of the gas tank that's behind the seat. I know the capacity (19 gal or so) but I'm thinking of moving the tank to the bed and I want to know if it's feasible.
Thanks.
Sweet Willy
Sweet Willy is offline   Reply With Quote
Old 08-13-2014, 03:08 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: odd question... maybe
yes it is, speak to Pro Performance, they sell Boyd Welding tanks that fit nicely between the frame rails.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-13-2014, 03:11 PM   #3
Sweet Willy
Thanks Clyde but I'm looking to moving it into the bed not below the frame.
Old 08-13-2014, 08:04 PM   #4
cortcomp
cortcomp's Avatar
If i recall there is like a 12 and a 21 gallon tank, the repops are all 21 gallon if i remember.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 08-13-2014, 09:40 PM   #5
Straydog
Fuel cell?
Straydog is offline   Reply With Quote
Old 08-13-2014, 09:52 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Are you wanting to know if the tank in cab will fit in the bed?
66 C20 Service Truck:
Old 08-13-2014, 11:08 PM   #7
Sweet Willy
I know it will fit in the bed. I'm trying to design something to put the tank in, in the bed and I need to know the actual measurements, i.e. 40" x 20" x whatever ". I don't have my truck yet so I can't run outside and take the measurements.
Old 08-14-2014, 06:44 AM   #8
PGSigns
PGSigns's Avatar
Not going to fit in the stepside bed. Not side to side anyway.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-14-2014, 06:56 AM   #9
72freak
Rottenwood Garage Member
72freak's Avatar
Although it wont fit, since you were willing to spend all those man hours fabricating a way to put it in the bed, why not do it correctly and put one under the truck where it needs to be? If you don't want to spend the money on a new conversion go get a junk yard Blazer or S10 tank and fab it where it wont be seen?!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 08-14-2014, 09:51 AM   #10
T2vigil
T2vigil's Avatar
Willy FYI - If you go the route of building a tank keep in mind the weight you will have above the center of gravity. If you have a tank in the bed and have a 12" X 12" X 53" you will have about 210 Pounds in the bed and that could mess up and handling you might have.
T2vigil is offline   Reply With Quote
Old 08-16-2014, 10:36 AM   #11
gixxer711
LMC has a new tank that mounts under the bed and the filler comes thru the floor for $200. That is the cheapest thing going.
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=56
Danny
64 C10 SWB fleet
gixxer711 is offline   Reply With Quote
Old 08-16-2014, 12:18 PM   #12
ImpalaJim
ImpalaJim's Avatar
I hate the through the floor tanks! I bought there other style and the flippen fill tube is right where the cross member needs to be
ImpalaJim is offline   Reply With Quote
Old 08-16-2014, 12:46 PM   #13
T2vigil
T2vigil's Avatar
I installed the Blazer tank under the bed and brought the filler neck out into the driver side fender using one of the motorcycle filler caps. I would post photos if someone could walk me through the process. I have tried in the past without any success.
Old 08-16-2014, 11:21 PM   #14
gixxer711
Sounds like you got the blazer tank with the angled neck. They built a new one that's like the blazer tank but the neck is straight up and designed to go thru the wood between the metal slats.
Danny
64 C10 SWB fleet
Old 08-17-2014, 06:37 PM   #15
T2vigil
T2vigil's Avatar
Yes I did get one with the angle filler neck. I did have to flame bend the top flange of the frame. I used hose from Lowes that is rated for fuel and used a heat gun to help with the bending. And a great hand to McCoyAZ for helping me upload photos.
Old 08-17-2014, 06:47 PM   #16
T2vigil
T2vigil's Avatar
A few more photos
Old 08-20-2014, 09:17 AM   #17
curvedglass
curvedglass's Avatar
when you say flame bend the flange - which flange are you talking about? Also I would like to know where you got the filler cap. Looks sweet. I have a 63 short fleet and I want to move my tank. I do not want to fill from the bed because I will be covering the bed and I work in NJ where they still pump your gas. The pump jockeys will rip my cover snaps faster than $hit.
Thanks for the cool post.
curvedglass is offline   Reply With Quote
Old 08-20-2014, 06:56 PM   #18
T2vigil
T2vigil's Avatar
I took a torch to the top of the "C" portion of the frame and bent it down to gain some more clearance. I used an adjustable wrench and not a hammer so I could make it look it came from the factory. If you look at the last photo you can see where the filler hose comes over the frame. I got the filler cap from Speedway. A bit pricey but I only needed one for the look I wanted. I will have to say I do not know if it will work for a fleetside. Also a heads up on the cap itself. If you do not take a little time / brains someone could screw up the aluminum threads.
Old 08-21-2014, 06:42 AM   #19
curvedglass
cool. thankx for the info. good to know about the threads. i'll have to see what other options i have for a filler door. I thought about grafting one in from a car but that means body work and paint. I like the old retro camper style fuel doors that were used when aftermarket saddle tanks were installed. Pop rivets and all.
