Glass Replacement
Hi,
So i have an 83 k10 which i broke the glass in my passenger side. I could just order the glass, but i dont know how to put it into the old window sash. Would this fit fine? http://www.ebay.com/itm/73-87-Chevy-...2443f7&vxp=mtr Thanks! |
![]() Join Date: Feb 2014
Re: Glass Replacement
That glass should work for you. The info below is from another thread I posted a little ago.
This is how I install glass on doors equipped with manual regulators. It has been a long time since I have messed with power regulators in a Square. With the vent window assembly out of the door and the the lower retainer bolt out of the the bottom of the opposite track, roll the regulator all the way up. The rollers will extend up into the opening. Slide the glass onto the rollers and carefully roll down the window. When the window is all the way down slide the glass towards the latch side of the door as far as you can without the glass falling off of the track. Install the vent window assembly. Slide the glass towards the vent window track. Align the lower latch side track and install retainer bolt. Test the window for smooth operation making any adjustments as necessary. Hope this helps. Chris
86 Chevrolet K10 350/SM465 Frankie SOLD 1995 GMC Yukon GT SOLD 1996 GMC Yukon GT 2010 Suburban 1500 4x4 5.3l/6L80e. Sold 2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e |
| Bookmarks |
