Old 08-13-2014, 08:16 PM   #1
warbucket
warbucket's Avatar
GM 14 bolt backlash ?
My 14 bolt has a whine over 30 mph while on the gas and cruising but it will stop when I let off the gas. I don't know the miles on the axle, it's from a CUCV. Can I adjust the backlash using a dial indicator and some marking compound to eliminate the whine, maybe move the carrier closer to the pinion, or are the gears done.
A local shop said the R&P need to be replaced because there is too much play in the pinion, I told him it had a Detroit locker in it, it should have play.
72 CST 4x4 Blazer, 1 ton
70 SS Chevelle, L78, 396
Everytime someone calls your Blazer a Bronco, God kills a kitten.
warbucket is offline   Reply With Quote
Old 08-14-2014, 04:35 PM   #2
obijuan
Re: GM 14 bolt backlash ?
Read the 14 bolt bible on pirate4x4
obijuan is offline   Reply With Quote
Old 08-14-2014, 08:16 PM   #3
cableguy0
Once gears start to make noise they were either set up wrong in the first place or just worn out. Either way you need a new gear seat. Play between the ring and pinion has nothing to do with whether you have an open rear,locker or a posi unit. If the pinion has excessive movement the gears are worn out.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 08-14-2014, 08:27 PM   #4
warbucket
warbucket's Avatar
Thanks Guys, Looks like new gears and install kit it is but which one's? I don't trust the super low price one's. It's been a long time since I've had to re gear an axle.
Old 08-14-2014, 08:48 PM   #5
obijuan
The Detroit will rotate the pinion nearly a 1/4 turn. But the backlash is not affected by it. G2 is a good brand that I install nearly 10 axles a month in. I put 3 year 36k warranties on em. Excellent products. Have you taken the diff cover off yet?
Old 08-14-2014, 09:27 PM   #6
warbucket
warbucket's Avatar
Yes. I took the cover off to take a look and change the oil. That was before I drove it. I just got it back on the road when I noticed the whine.
